I have a Toshiba laptop using Vista Home Premium. The pc includes a built in
SD reader which has continual problems (after sleep). From my research it
appears I need to install the rollup patch 936825
(http://support.microsoft.com/default.aspx/kb/936825/) which should fix the
sleep issues.
When I try and install it I get:
The update does not apply to your system
Why do I get this? How do I get the patch to install?
Thanks in advance for any help. I am new to Vista.
