Vista - USB Flash Drives for 64 Bit Vista Home Premium
Old 11-24-2007   #1 (permalink)
Hunters
My 64 Bit Vista Home Premium will not find drivers for USB Flash Drives Lexar
Firefly 512MB, purchased 11/21 and SAndiskCruzer Micro 2GB, purchased 11/23.
Or any others for that matter but they all work with 32 Bit. Can anyone send
me to a list of compatable 64 Bit Flash Drives?
Old 11-24-2007   #2 (permalink)
Kerry Brown
Re: USB Flash Drives for 64 Bit Vista Home Premium
Make sure you have this update installed.
http://support.microsoft.com/kb/941600
If that doesn't fix it then I suspect the problem is with your motherboard
or USB chipset driver. Do other USB devices work OK?
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
"Hunters" <Hunters@xxxxxx> wrote in message
news:F33319E0-343C-40BF-BA3C-98D8C6F57918@xxxxxx
> Lexar
> 11/23.
> send
Old 11-24-2007   #3 (permalink)
Hunters
Yes they do. I'll check the update. As additional backgroud I spent 3 hours
with windows support they tried several things including teleconferencing
with the manufacturers and they said although it says "Works with Vista" it
applies to the 32 bit version. I have 32 Bit loaded on dual boot config.
The drives work when I chose to boot it on the same computer.
> Kerry Brown
> > Lexar
> > 11/23.
> > send
Old 11-24-2007   #4 (permalink)
Hunters
As an additional note I tried to download the update but it says its does not
apply to my system. My system runs 64 Bit since I built it 2 months ago as
my primary OS. All components are 64 Bit capable.
> Kerry Brown
> > Lexar
> > 11/23.
> > send
Old 11-24-2007   #5 (permalink)
Kerry Brown
What motherboard do you have? I know it doesn't help your situation but it's
not a 64 bit Vista problem. I have tried many different flash drives and a
few USB hard drives on two different systems running 64 bit Vista. So far I
haven't found any that don't work.
Kerry Brown
news:E150CFC0-9E7F-4F16-9508-FB0CD5ABBEB2@xxxxxx
> not
> as
>> motherboard
>> Kerry Brown
>> > Lexar
>> > 11/23.
>> > anyone
>> > send
Old 11-25-2007   #6 (permalink)
Barb Bowman
Some of the Cruzer's shipped with a U3 program that is not very
friendly to x64 Vista. There is a removal tool at
http://www.u3.com/uninstall/ (which you may need to run on an XP
machine if you can find one). This might be complicating a different
issue.
On Sat, 24 Nov 2007 08:14:00 -0800, Hunters
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
Old 11-25-2007   #7 (permalink)
Kerry Brown
Good point. I haven't tried any U3 devices with Vista x64.
Kerry Brown
"Barb Bowman" <barb@xxxxxx> wrote in message
news:hknik3tujunaothb006noobotj34eimkj3@xxxxxx
> issue.
>>Lexar
>>11/23.
>>send
> Barb Bowman
> MS Windows-MVP
Old 11-25-2007   #8 (permalink)
Hunters
First of all, thank you both for providing suggestions and insights into this
issue. I'm using a nForce 680i SLI by EVGA. The New T1 version with 64 bit
hyperthreading technology, supports 4GB with 32 bit and 8GB using 64 bit. I
use a Quad Core CPU as well.
> Kerry Brown
> > not
> > as
> >> motherboard
> >> Kerry Brown
> >> > Lexar
> >> > 11/23.
> >> > anyone
> >> > send
Old 11-26-2007   #9 (permalink)
Kerry Brown
Are you using the latest NVidia chipset driver?
Kerry Brown
news:B48EB4BB-2824-4DFC-95E3-F2D631F36050@xxxxxx
> this
> bit
> I
>> it's
>> a
>> I
>> Kerry Brown
>> > does
>> > not
>> > ago
>> > as
>> >> motherboard
>> >> Kerry Brown
>> >> > Drives
>> >> > Lexar
>> >> > purchased
>> >> > 11/23.
>> >> > anyone
>> >> > send
Vista Home Premium 32bit can't recognize Kingston 2.0 1GB USB Flash Drive Vista hardware & devices
Problem downloading Adobe Flash Player 9 to Vista Home Premium Vista General
Vista Home Premium Won't Recognize My Old Hard Drives Vista hardware & devices
Windows Vista Home Premium & Network Drives Vista networking & sharing
Adobe Flash 9 Windows Vista Home Premium Vista General
