| Guest | AIC-7870 SCSI adapter problems I have a Scorpion STD2401LW tape drive, which works fine with Linux. The vendor provided an AIC-7870 SCSI-PCI adapter to support it. Thus far I have been unable to install the adapter under Vista, using a driver downloaded from the Adaptec Web site. (Whether the drive itself would be supported, I don't yet know.) Does anyone have this adapter working on Vista? Also, is there a somewhat comprehensive list of supporte devices? |
| USB Bluetooth adapter problems | General Discussion | |||
| Problems turning on wireless adapter | Network & Sharing | |||
| Adding SCSI Adapter | Virtual Server | |||
| Replaced SCSI adapter, system won’t boot. | Vista hardware & devices | |||
| Anyone know of a SCSI U320 adapter that has Vista 64 support? | Drivers | |||
