| | Scanners and Cameras Applet Problem Hopefully, this will get some attention here! I recently installed Nuance PaperPort 11 for Vista onto my computer. I also installed the Vista drivers for my HP ScanJet 5590. I should be able to assign the five buttons on the front of the 5590 using the Events tab on the Scanners and Cameras Control Panel applet in Vista to launch PaperPort from any of those buttons. I should then be able to assign particular scan profiles for each of those buttons from the Options/Buttons menus in PaperPort. The latter cannot be done without the former! However, when I attempt to change the Action on the Event menu in the Control Panel applet, I receive an "Event registration failed" error that states, "The attempt to change the registered event handler failed. Please make sure the device is turned on and connected properly." The device is turned on and connected properly and functions. I have attached a snip of the error and screens to this message. If someone has experienced this and has a solution, please reply. Thanks! |
| No Wireless connection in "Scanners and Cameras" | Vista print fax & scan | |||
| Re: Scanners and Cameras | Vista print fax & scan | |||
| MSFT VX6000 Lifecam not showing in "Scanners & Cameras" | Vista hardware & devices | |||
| Scanners and Cameras | Vista General | |||
| Cameras and Scanners Control Panel applet Missing. | Vista General | |||
