| | External Hard Drive Problem I just bought a Dell Inspirion 531 with Vista since my old computer (XP) would no longer function. In order to access the files from the old HD, I installed it in a Metal Gear Box 3506 UC 3.5" enclosure and connected it to the USB connection of the new computer. Initially I could see the files, but after rebooting my computer I received an error message stating that the drive is not accessible and the disk structure is corrupted and unreadable. All I want to do is move the files from my old computer HD to the new computer HD. Any suggestions would be gratefully appreciated. |
| | Re: External Hard Drive Problem Hi, CAS. We can't help much unless you tell us more about your old hard drive. And Vista has kind of the same sort of problem. :>( What does Disk Management tell you about that drive? Run DM (diskmgmt.msc) and check out its Help file. You probably need to "initialize" that "foreign" hard drive. If you need to post back, please tell us the make and model of that hard drive, and its interface (IDE/ATA/PATA, SATA, SCSI - or what?). RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2008 in Vista Ultimate x64) "CAS" <CAS@xxxxxx> wrote in message news:B3AC6569-3D26-487C-ABBB-63B57C18DF11@xxxxxx Quote: > I just bought a Dell Inspirion 531 with Vista since my old computer (XP) > would no longer function. In order to access the files from the old HD, I > installed it in a Metal Gear Box 3506 UC 3.5" enclosure and connected it > to > the USB connection of the new computer. Initially I could see the files, > but > after rebooting my computer I received an error message stating that the > drive is not accessible and the disk structure is corrupted and > unreadable. > > All I want to do is move the files from my old computer HD to the new > computer HD. > > Any suggestions would be gratefully appreciated. |
| | Re: External Hard Drive Problem RC: Thanks for the reply. The hard drive is a Western Digital enhanced IDE. The model is WD1200JB-75CRA0 and it is 120 GB. Since I could not find the "run" function on Vista I went to 'control panel', 'computer management' and then to 'disk management'. It lists this hard drive as "111.76 GB RAW/Healthy(Primary Partition). Also, when I go to 'error checking' in 'properties' I get the following error message: "The disk check could not be performed because Windows cannot access the disk" Hope this helps. My goal is to save the data that is on this old hard drive and move it over to the hard drive in my new dell computer. Rgds, CAS "R. C. White" wrote: Quote: > Hi, CAS. > > We can't help much unless you tell us more about your old hard drive. And > Vista has kind of the same sort of problem. :>( > > What does Disk Management tell you about that drive? Run DM (diskmgmt.msc) > and check out its Help file. You probably need to "initialize" that > "foreign" hard drive. > > If you need to post back, please tell us the make and model of that hard > drive, and its interface (IDE/ATA/PATA, SATA, SCSI - or what?). > > RC > -- > R. C. White, CPA > San Marcos, TX > rc@xxxxxx > Microsoft Windows MVP > (Running Windows Live Mail 2008 in Vista Ultimate x64) > > "CAS" <CAS@xxxxxx> wrote in message > news:B3AC6569-3D26-487C-ABBB-63B57C18DF11@xxxxxx Quote: > > I just bought a Dell Inspirion 531 with Vista since my old computer (XP) > > would no longer function. In order to access the files from the old HD, I > > installed it in a Metal Gear Box 3506 UC 3.5" enclosure and connected it > > to > > the USB connection of the new computer. Initially I could see the files, > > but > > after rebooting my computer I received an error message stating that the > > drive is not accessible and the disk structure is corrupted and > > unreadable. > > > > All I want to do is move the files from my old computer HD to the new > > computer HD. > > > > Any suggestions would be gratefully appreciated. |
| | Re: External Hard Drive Problem Hi, CAS. Whoops! I meant to get back to you a couple of days ago. :^{ Quote: > Since I could not find the > "run" function on Vista I went to 'control panel', 'computer management' > and > then to 'disk management'. them. Just click the Start orb (or press the Windows logo key) and start typing. Your keystrokes go into the Search box, so type "diskmgmt.msc" (without the quotes), then press Enter. You'll still need to furnish Administrator credentials, because this is a very powerful utility that can do harm as well as good. I prefer this direct method of starting Disk Management for several reasons, mostly because it does not carry along the screen real estate "overhead" of the many-mouse-clicks path through Control Panel | Computer Management. It irritates me that I can't make DM remember that I want to see it in a Maximized window and with wider columns, but this view is still better than the "keyhole" view that I get the other way. In Vista (as in WinXP), you also can Run any command by pressing <Win>+R. And you can put the Run command back on Vista's Start menu by right-clicking on the Start orb, then click Properties, then the Customize button for Start menu on the Start Menu tab. On this screen, you can customize the Start menu in several ways, including checking the box for Run command. Anyhow...Once in Disk Management, click Help | Help Topics. This should bring up the home page for Microsoft Management Console 3.0, since Disk Management is a "snap-in" under the MMC. Click the Search tab on the left, then type in "foreign" and click List Topics (or just press Enter). You should see 3 topics, all in the DM "Location". All 3 are interesting, but the second one, "Move Disks to Another Computer", is most on point for your problem. This version of the Help file puts a lot of emphasis on a couple of features that most of us don't use at all, so we have to kind of "read around" all the info about "GUID partition table disks" and dynamic disks. But there is plenty of info here that applies to us one-man-one-computer guys like me (and you?). The key paragraph on that Help page says: <paste> Detect new disks On the new computer, open Disk Management. Click Action and then click Rescan Disks. Right-click any disk marked Foreign, click Import Foreign Disks, and then follow the instructions on your screen. </paste> DM doesn't know much about what to do with a "RAW" disk but to format it, since that usually means that it hasn't been formatted. :>( This should get you going, but if it doesn't, please post back and I'll try to be more prompt next time. RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2008 in Vista Ultimate x64) "CAS" <CAS@xxxxxx> wrote in message news:F2CCAB2E-13F7-4F9E-895C-251897A8B20D@xxxxxx Quote: > RC: > > Thanks for the reply. The hard drive is a Western Digital enhanced IDE. > The model is WD1200JB-75CRA0 and it is 120 GB. Since I could not find the > "run" function on Vista I went to 'control panel', 'computer management' > and > then to 'disk management'. It lists this hard drive as "111.76 GB > RAW/Healthy(Primary Partition). > > Also, when I go to 'error checking' in 'properties' I get the following > error message: "The disk check could not be performed because Windows > cannot > access the disk" > > Hope this helps. > > My goal is to save the data that is on this old hard drive and move it > over > to the hard drive in my new dell computer. > > Rgds, > > CAS > > "R. C. White" wrote: > Quote: >> Hi, CAS. >> >> We can't help much unless you tell us more about your old hard drive. >> And >> Vista has kind of the same sort of problem. :>( >> >> What does Disk Management tell you about that drive? Run DM >> (diskmgmt.msc) >> and check out its Help file. You probably need to "initialize" that >> "foreign" hard drive. >> >> If you need to post back, please tell us the make and model of that hard >> drive, and its interface (IDE/ATA/PATA, SATA, SCSI - or what?). >> >> RC >> >> "CAS" <CAS@xxxxxx> wrote in message >> news:B3AC6569-3D26-487C-ABBB-63B57C18DF11@xxxxxx Quote: >> > I just bought a Dell Inspirion 531 with Vista since my old computer >> > (XP) >> > would no longer function. In order to access the files from the old >> > HD, I >> > installed it in a Metal Gear Box 3506 UC 3.5" enclosure and connected >> > it >> > to >> > the USB connection of the new computer. Initially I could see the >> > files, >> > but >> > after rebooting my computer I received an error message stating that >> > the >> > drive is not accessible and the disk structure is corrupted and >> > unreadable. >> > >> > All I want to do is move the files from my old computer HD to the new >> > computer HD. >> > >> > Any suggestions would be gratefully appreciated. |
| | Re: External Hard Drive Problem RC: Thanks for the detailed reply. By the way, what is a 'raw file'? I followed your instructions, but nothing happened when I clicked on 'rescan disks'. The curser changed to the circle for a few seconds and then stopped/changed back to the curser. Nothing regarding 'foreign' came up on the screen. Would a recovery program be useful at this point? Also, what about the fact that when I go to 'error checking' in 'properties' I get the following error message: "The disk check could not be performed because Windows cannot access the disk" ? Your patience with this problem is appreciated. Rgds, CAS "R. C. White" wrote: Quote: > Hi, CAS. > > Whoops! I meant to get back to you a couple of days ago. :^{ > Quote: > > Since I could not find the > > "run" function on Vista I went to 'control panel', 'computer management' > > and > > then to 'disk management'. > There are several ways to "Run" in Vista, but you don't really need any of > them. Just click the Start orb (or press the Windows logo key) and start > typing. Your keystrokes go into the Search box, so type "diskmgmt.msc" > (without the quotes), then press Enter. You'll still need to furnish > Administrator credentials, because this is a very powerful utility that can > do harm as well as good. > > I prefer this direct method of starting Disk Management for several reasons, > mostly because it does not carry along the screen real estate "overhead" of > the many-mouse-clicks path through Control Panel | Computer Management. It > irritates me that I can't make DM remember that I want to see it in a > Maximized window and with wider columns, but this view is still better than > the "keyhole" view that I get the other way. > > In Vista (as in WinXP), you also can Run any command by pressing <Win>+R. > And you can put the Run command back on Vista's Start menu by right-clicking > on the Start orb, then click Properties, then the Customize button for Start > menu on the Start Menu tab. On this screen, you can customize the Start > menu in several ways, including checking the box for Run command. > > Anyhow...Once in Disk Management, click Help | Help Topics. This should > bring up the home page for Microsoft Management Console 3.0, since Disk > Management is a "snap-in" under the MMC. Click the Search tab on the left, > then type in "foreign" and click List Topics (or just press Enter). You > should see 3 topics, all in the DM "Location". All 3 are interesting, but > the second one, "Move Disks to Another Computer", is most on point for your > problem. This version of the Help file puts a lot of emphasis on a couple > of features that most of us don't use at all, so we have to kind of "read > around" all the info about "GUID partition table disks" and dynamic disks. > But there is plenty of info here that applies to us one-man-one-computer > guys like me (and you?). > > The key paragraph on that Help page says: > <paste> > Detect new disks > On the new computer, open Disk Management. Click Action and then click > Rescan Disks. Right-click any disk marked Foreign, click Import Foreign > Disks, and then follow the instructions on your screen. > </paste> > > DM doesn't know much about what to do with a "RAW" disk but to format it, > since that usually means that it hasn't been formatted. :>( > > This should get you going, but if it doesn't, please post back and I'll try > to be more prompt next time. > > RC > -- > R. C. White, CPA > San Marcos, TX > rc@xxxxxx > Microsoft Windows MVP > (Running Windows Live Mail 2008 in Vista Ultimate x64) > > "CAS" <CAS@xxxxxx> wrote in message > news:F2CCAB2E-13F7-4F9E-895C-251897A8B20D@xxxxxx Quote: > > RC: > > > > Thanks for the reply. The hard drive is a Western Digital enhanced IDE. > > The model is WD1200JB-75CRA0 and it is 120 GB. Since I could not find the > > "run" function on Vista I went to 'control panel', 'computer management' > > and > > then to 'disk management'. It lists this hard drive as "111.76 GB > > RAW/Healthy(Primary Partition). > > > > Also, when I go to 'error checking' in 'properties' I get the following > > error message: "The disk check could not be performed because Windows > > cannot > > access the disk" > > > > Hope this helps. > > > > My goal is to save the data that is on this old hard drive and move it > > over > > to the hard drive in my new dell computer. > > > > Rgds, > > > > CAS > > > > "R. C. White" wrote: > > Quote: > >> Hi, CAS. > >> > >> We can't help much unless you tell us more about your old hard drive. > >> And > >> Vista has kind of the same sort of problem. :>( > >> > >> What does Disk Management tell you about that drive? Run DM > >> (diskmgmt.msc) > >> and check out its Help file. You probably need to "initialize" that > >> "foreign" hard drive. > >> > >> If you need to post back, please tell us the make and model of that hard > >> drive, and its interface (IDE/ATA/PATA, SATA, SCSI - or what?). > >> > >> RC > >> > >> "CAS" <CAS@xxxxxx> wrote in message > >> news:B3AC6569-3D26-487C-ABBB-63B57C18DF11@xxxxxx > >> > I just bought a Dell Inspirion 531 with Vista since my old computer > >> > (XP) > >> > would no longer function. In order to access the files from the old > >> > HD, I > >> > installed it in a Metal Gear Box 3506 UC 3.5" enclosure and connected > >> > it > >> > to > >> > the USB connection of the new computer. Initially I could see the > >> > files, > >> > but > >> > after rebooting my computer I received an error message stating that > >> > the > >> > drive is not accessible and the disk structure is corrupted and > >> > unreadable. > >> > > >> > All I want to do is move the files from my old computer HD to the new > >> > computer HD. > >> > > >> > Any suggestions would be gratefully appreciated. |
| | #6 (permalink) |
| | Re: External Hard Drive Problem Hi, CAS. Well, so much for my "try to be more prompt next time". :>( I'm still hoping someone else will jump in and point out whatever it is that I must have overlooked. "Raw" means different things in different contexts. When Disk Management says "RAW", it's not talking about a file, but about a whole volume (partition or logical drive). It means that it thinks that volume has not been formatted. Usually this means that we need to format it, NTFS or FAT. But we don't want to do that, of course, unless we are sure that there's nothing on that volume that we want to keep! Sometimes there is a glitch in the partition table or other key location that says a drive is RAW when it really does have data on it. The critical code is probably only a single byte. The partition table is only 64 bytes long, up to 4 entries of 16 bytes each, and each byte has a very specific purpose. For example, at byte 01C2h is the System ID for the first partition; 07h here indicates that this partition holds an "Installable File System (NTFS partition or logical drive)", according to the WinXP Resource Kit. A 08h here would mean a FAT32 partition or logical drive. If some celestial accident caused this one byte to become 00h, then DM might think that the disk is unformatted - RAW - even if all the rest of the drive is undamaged. That - or some similar error - might trigger the disk check error message you are seeing. Quote: > Would a recovery program be useful at this point? without the necessity of such a program. Maybe there was a problem in installing and connecting your USB enclosure. I've never worked with one of those at all. Maybe it's time to call Microsoft Tech Support. Please let us know the final resolution so that we will know how to advise the next user with a similar problem. RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2008 in Vista Ultimate x64) "CAS" <CAS@xxxxxx> wrote in message news:EDC3C413-CFFD-46CC-A7E9-C5BC166FE6D0@xxxxxx Quote: > RC: > > Thanks for the detailed reply. By the way, what is a 'raw file'? > > I followed your instructions, but nothing happened when I clicked on > 'rescan > disks'. The curser changed to the circle for a few seconds and then > stopped/changed back to the curser. Nothing regarding 'foreign' came up > on > the screen. > > Would a recovery program be useful at this point? > > Also, what about the fact that when I go to 'error checking' in > 'properties' > I get the following error message: "The disk check could not be performed > because Windows cannot access the disk" ? > > Your patience with this problem is appreciated. > > Rgds, > > CAS > > "R. C. White" wrote: > Quote: >> Hi, CAS. >> >> Whoops! I meant to get back to you a couple of days ago. :^{ >> Quote: >> > Since I could not find the >> > "run" function on Vista I went to 'control panel', 'computer >> > management' >> > and >> > then to 'disk management'. >> There are several ways to "Run" in Vista, but you don't really need any >> of >> them. Just click the Start orb (or press the Windows logo key) and start >> typing. Your keystrokes go into the Search box, so type "diskmgmt.msc" >> (without the quotes), then press Enter. You'll still need to furnish >> Administrator credentials, because this is a very powerful utility that >> can >> do harm as well as good. >> >> I prefer this direct method of starting Disk Management for several >> reasons, >> mostly because it does not carry along the screen real estate "overhead" >> of >> the many-mouse-clicks path through Control Panel | Computer Management. >> It >> irritates me that I can't make DM remember that I want to see it in a >> Maximized window and with wider columns, but this view is still better >> than >> the "keyhole" view that I get the other way. >> >> In Vista (as in WinXP), you also can Run any command by pressing <Win>+R. >> And you can put the Run command back on Vista's Start menu by >> right-clicking >> on the Start orb, then click Properties, then the Customize button for >> Start >> menu on the Start Menu tab. On this screen, you can customize the Start >> menu in several ways, including checking the box for Run command. >> >> Anyhow...Once in Disk Management, click Help | Help Topics. This should >> bring up the home page for Microsoft Management Console 3.0, since Disk >> Management is a "snap-in" under the MMC. Click the Search tab on the >> left, >> then type in "foreign" and click List Topics (or just press Enter). You >> should see 3 topics, all in the DM "Location". All 3 are interesting, >> but >> the second one, "Move Disks to Another Computer", is most on point for >> your >> problem. This version of the Help file puts a lot of emphasis on a >> couple >> of features that most of us don't use at all, so we have to kind of "read >> around" all the info about "GUID partition table disks" and dynamic >> disks. >> But there is plenty of info here that applies to us one-man-one-computer >> guys like me (and you?). >> >> The key paragraph on that Help page says: >> <paste> >> Detect new disks >> On the new computer, open Disk Management. Click Action and then click >> Rescan Disks. Right-click any disk marked Foreign, click Import Foreign >> Disks, and then follow the instructions on your screen. >> </paste> >> >> DM doesn't know much about what to do with a "RAW" disk but to format it, >> since that usually means that it hasn't been formatted. :>( >> >> This should get you going, but if it doesn't, please post back and I'll >> try >> to be more prompt next time. >> >> RC >> >> "CAS" <CAS@xxxxxx> wrote in message >> news:F2CCAB2E-13F7-4F9E-895C-251897A8B20D@xxxxxx Quote: >> > RC: >> > >> > Thanks for the reply. The hard drive is a Western Digital enhanced >> > IDE. >> > The model is WD1200JB-75CRA0 and it is 120 GB. Since I could not find >> > the >> > "run" function on Vista I went to 'control panel', 'computer >> > management' >> > and >> > then to 'disk management'. It lists this hard drive as "111.76 GB >> > RAW/Healthy(Primary Partition). >> > >> > Also, when I go to 'error checking' in 'properties' I get the following >> > error message: "The disk check could not be performed because Windows >> > cannot >> > access the disk" >> > >> > Hope this helps. >> > >> > My goal is to save the data that is on this old hard drive and move it >> > over >> > to the hard drive in my new dell computer. >> > >> > Rgds, >> > >> > CAS >> > >> > "R. C. White" wrote: >> > >> >> Hi, CAS. >> >> >> >> We can't help much unless you tell us more about your old hard drive. >> >> And >> >> Vista has kind of the same sort of problem. :>( >> >> >> >> What does Disk Management tell you about that drive? Run DM >> >> (diskmgmt.msc) >> >> and check out its Help file. You probably need to "initialize" that >> >> "foreign" hard drive. >> >> >> >> If you need to post back, please tell us the make and model of that >> >> hard >> >> drive, and its interface (IDE/ATA/PATA, SATA, SCSI - or what?). >> >> >> >> RC >> >> >> >> "CAS" <CAS@xxxxxx> wrote in message >> >> news:B3AC6569-3D26-487C-ABBB-63B57C18DF11@xxxxxx >> >> > I just bought a Dell Inspirion 531 with Vista since my old computer >> >> > (XP) >> >> > would no longer function. In order to access the files from the old >> >> > HD, I >> >> > installed it in a Metal Gear Box 3506 UC 3.5" enclosure and >> >> > connected >> >> > it >> >> > to >> >> > the USB connection of the new computer. Initially I could see the >> >> > files, >> >> > but >> >> > after rebooting my computer I received an error message stating that >> >> > the >> >> > drive is not accessible and the disk structure is corrupted and >> >> > unreadable. >> >> > >> >> > All I want to do is move the files from my old computer HD to the >> >> > new >> >> > computer HD. >> >> > >> >> > Any suggestions would be gratefully appreciated. |
| 1 TB External Hard Drive Problem | Vista hardware & devices | |||
| USB external hard drive problem. | Vista hardware & devices | |||
| External Hard Drive PROBLEM ~~ Need HELP! | Vista General | |||
| External hard drive problem | Vista General | |||
