| | USB Devices not installing corectly I have a Toshiba P100 running Vista. There are a number of devices that just won't install correctly. IPOD, HP Deskjet F380, Freecom 500GB Ext HD. Issue I get is that they appear in Device Manager, and Vista recognises them. But even with the drivers installed - HP driver from website and CD tried, IPOD obviously just uses iTunes, and HD which is plug and play no CD driver supplied - the system won't accept the devices as fully installed. It keeps asking for the driver CD. Any thoughts? |
| | RE: USB Devices not installing corectly "Maximus" wrote: Quote: > I have a Toshiba P100 running Vista. There are a number of devices that just > won't install correctly. IPOD, HP Deskjet F380, Freecom 500GB Ext HD. > > Issue I get is that they appear in Device Manager, and Vista recognises > them. But even with the drivers installed - HP driver from website and CD > tried, IPOD obviously just uses iTunes, and HD which is plug and play no CD > driver supplied - the system won't accept the devices as fully installed. It > keeps asking for the driver CD. > > Any thoughts? |
| | RE: USB Devices not installing corectly Max - have you heard from anyone? My neighbor just bought a Dell, high end desk top with Vista preimum on Saturday. The kids came home today with their flash memory data travelers with home work assignments and those flash media won't work. When you install the flash travelers Vista says, like it does to you, searching for drivers, then, there are no drivers. I contacted the flash traveler company (Kingston) and they advise they are getting a lot of calls. According to them, there are no drivers, the problem is a flaw that occurred when the OS was installed; they offered no solutions. The new system didn't come with a copy of Vista premium, so there is no way to try and reinstall Vista. So, we're wondering how they fix their problem? Any ideas -- anyone? "Maximus" wrote: Quote: > I have a Toshiba P100 running Vista. There are a number of devices that just > won't install correctly. IPOD, HP Deskjet F380, Freecom 500GB Ext HD. > > Issue I get is that they appear in Device Manager, and Vista recognises > them. But even with the drivers installed - HP driver from website and CD > tried, IPOD obviously just uses iTunes, and HD which is plug and play no CD > driver supplied - the system won't accept the devices as fully installed. It > keeps asking for the driver CD. > > Any thoughts? |
| | Re: USB Devices not installing corectly If your system didn't come with disks, then there is a utility to make a "restore disk" from the protected partition on your hard drive. If you run this program it will make a CD you can boot from and you can then either reinstall or repair Vista. You should do this in any event. "Anthelia" <Anthelia@xxxxxx> wrote in message news:39CBDCA4-1E6A-440E-992F-4387D743F8C9@xxxxxx Quote: > Max - have you heard from anyone? My neighbor just bought a Dell, high end > desk top with Vista preimum on Saturday. The kids came home today with > their > flash memory data travelers with home work assignments and those flash > media > won't work. When you install the flash travelers Vista says, like it does > to > you, searching for drivers, then, there are no drivers. I contacted the > flash traveler company (Kingston) and they advise they are getting a lot > of > calls. According to them, there are no drivers, the problem is a flaw > that > occurred when the OS was installed; they offered no solutions. The new > system didn't come with a copy of Vista premium, so there is no way to try > and reinstall Vista. So, we're wondering how they fix their problem? Any > ideas -- anyone? > > "Maximus" wrote: > Quote: >> I have a Toshiba P100 running Vista. There are a number of devices that >> just >> won't install correctly. IPOD, HP Deskjet F380, Freecom 500GB Ext HD. >> >> Issue I get is that they appear in Device Manager, and Vista recognises >> them. But even with the drivers installed - HP driver from website and >> CD >> tried, IPOD obviously just uses iTunes, and HD which is plug and play no >> CD >> driver supplied - the system won't accept the devices as fully installed. >> It >> keeps asking for the driver CD. >> >> Any thoughts? |
| | #6 (permalink) |
| | RE: USB Devices not installing corectly "Maximus" wrote: Quote: > I have a Toshiba P100 running Vista. There are a number of devices that just > won't install correctly. IPOD, HP Deskjet F380, Freecom 500GB Ext HD. > > Issue I get is that they appear in Device Manager, and Vista recognises > them. But even with the drivers installed - HP driver from website and CD > tried, IPOD obviously just uses iTunes, and HD which is plug and play no CD > driver supplied - the system won't accept the devices as fully installed. It > keeps asking for the driver CD. > > Any thoughts? :\windows\windows32 this resolved the problem I was having installing an iPod Classic |
| Access to vista component devices of playback devices likemicrophone, linein, front mic etc in vc++ | Vista hardware & devices | |||
| Access vista component devices of playback devices like microphone,linein, front mic etc in vc++ | Vista General | |||
| Installing new devices | Vista hardware & devices | |||
| USB Devices not installing | Vista hardware & devices | |||
| vista always installing new devices at boot | Vista hardware & devices | |||
