Does anyone know what Intel Processors are 64-bit and which are 32-bit?
Thanks.
Thanks.
http://www.intel.com/
Check with the source.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
* HELP us help YOU ... http://www.dts-l.org/goodpost.htm
"otj" <otj@xxxxxx> wrote in message
news:AC2D48FB-47A3-479C-B771-D12B4DEFFE4D@xxxxxx
> Thanks.
Most of the current ones are 64 Bit capable. You can download a program
called CPUZ that will tell you which you have: http://www.cpuid.com/cpuz.php
If you are just looking at which model to choose to buy, you can check
Newegg.com and it tells you if it is 64 Bit.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com
> Thanks.
| Similar Threads | ||||
| How many processors will vista take.... | Steve Thompson | Vista General | 8 | 07 Jun 2008 |
| dual processors | Dennis | Vista performance & maintenance | 3 | 10 Apr 2008 |
| OEM vs Retail processors... | hatehereyes | Overclocking & Cooling | 5 | 25 Feb 2008 |
| 64 bit processors. | Vista General | 7 | 10 Dec 2007 | |
| Duo Core Processors | Bob J | Vista General | 15 | 01 Aug 2007 |
