Vista - Secondary display problems vista 64
Old 12-11-2007   #1 (permalink)
David
Hi, my ATI 2600pro works with the secondary display, however Vista only
recognises the secondary as a generic non pnp monitor, I cant seem to update
the driver beyond this, its a problem because the ATi drivers only allow a
refresh rate of 25i on this screen, which is rubbish, looks like the hardware
isn't even being used.
It's a HD display and will support up to 1080i at up to 100hz, which it did
very well under XPpro at max resolution and 75hz under the same system setup.
I have tried changing it manually in vista, choose from a list, the list
doesnt populate, the ati drivers wont let me force anything.
However like is said this all worked well underXP (like many other things)
and now refuses to cooperate under vista (all for a bit of extra 64bit crysis
performance).
Please help, suggestions!
Thanks, David.
Powershell Wrapper Script Problems - Trying to Call PowershellExchange 2007 Commands from Secondary Language (Like VBScript) PowerShell
Problems with display when opening pdf in Vista Vista performance & maintenance
Windows Vista Display Problems Vista General
display problems in vista Vista hardware & devices
Vista RTM using TV as secondary display problems Vista General
