I've got a major problem that has me stumped...! Any help will be greatly appreciated.
  1. #1
    My Place Guest
    Here's the problem. I just bought from TigerDirect a refurbished
    Gateway computer - great power, just like I wanted, until I got it in
    last night. When I got to the plugging my old monitor in, a 3 row 15
    pin VGA, it was capped off with a plastic cap and tape saying "Do Not
    Use." So, I called a friend of mine who is a MicroSoft Beta tester,
    has a call in 2 hour radio program every Saturday (for 13+ years now)
    on our local station that reaches out about 400 miles. Anyway, after
    a rather short discussion, he describes a DVI connection , and BINGO,
    that's what I have.
    Does anyone know of a work around so I can keep my monitor, like
    putting a different video card in? I really don't like the idea of
    going to a flat screen. I have one PCI slot open, really two, cause I
    can remove the modem, since I'm on cable.
    Maybe there is an adapter which will allow me to use my old monitor
    and plug into the DVI socket, like the old null modem cables and
    gender changers, or something else along these lines.
    This computer has a TV Tuner card in it which I really wanted, not to
    watch TV on, but to record a lot of programs I have on VHS as well as
    some documentaries, and put these to DVD. So, I don't want to do
    anything that will cause a conflict with this card.
    I sent Gateway support an email last night, and here it is, 11:25
    P.M., and no reply yet.
    Any help or suggestions would be greatly appreciated.
    Thanks a million.
  2. #2
    Spirit Guest
    Re: I've got a major problem that has me stumped...! Any help will be greatly appreciated.
    http://www.nextag.com/dvi-to-vga-adapter/search-html
    <My Place> wrote in message
    news:2qh1m35o0c2pklm2k8uq9bt811tmledfk8@xxxxxx
    > Hi,
    > that's what I have.
    > Thanks a million.
  3. #3
    JW Guest
    That adapter will only work if the OP's system has a DVI-I connection and
    his graphics card driver supports using it for VGA. If the user manual does
    not say it supports a DVI to VGA adapter then it probably does not.
    It appears that who ever "refurbished" the system did not repair the VGA
    output if that was the cause of the system being returned in the first
    place. I think the system should be returned since it apparently does not
    meet it's original specifications.
    "Spirit" <unknown@xxxxxx> wrote in message
    news:%23qt$E6UPIHA.1188@xxxxxx
    >> Hi,
    >> that's what I have.
    >> Thanks a million.
  4. #4
    Mike Hall - MVP Guest
    TigerDirect haven't sold you a refurbished computer. They have sold you a
    BROKEN computer. Take it back NOW..
    Mike Hall - MVP
    http://msmvps.com/blogs/mikehall/default.aspx
    "My Place" wrote in message
    > Hi,
    > that's what I have.
    > Thanks a million.
  5. #5
    My Place Guest
    On Thu, 13 Dec 2007 06:04:36 -0800, "JW" <JW@xxxxxx> wrote:
    Hi JW,
    Thanks for the above info. Your opinion please: instead of using a
    VGA/DVI adapter, would it be "ok" to remove the modem and put a VGA
    video card in that PCI slot? The only "problem" I see right now is
    there is a connection (wires) running from the top of the DVI card to
    a plug on the motherboard. I can find out what this connection is
    next Monday, as Ira is leaving tomorrow for his daughter's wedding and
    won't return until late Sunday. Unfortunately, I didn't get a user
    manual.
    Thanks.
    >>> Hi,
    >>> that's what I have.
    >>> Thanks a million.
  6. #6
    JW Guest
    The plug is for an additional power connection.
    Since you got sold a broken computer I have no idea what would work or not
    work. However I think that could just remove either the modem or the DVI
    controller card and install a plain old VGA only card.
    news:46r2m3d5nbsbq7vge1q824vgjin953fce6@xxxxxx
    > Hi JW,
    >>does
    > manual.
    > Thanks.
    >>>> Hi,
    >>>> that's what I have.
    >>>> Thanks a million.
  7. #7
    You must have gotten the computer for a really good price.
    I fail to see the point of buying a high grade 'broken' machine into which
    you will pay for and install an inferior part. A refurbished machine should
    be fixed properly by the vendor, after which they can save on the repair
    cost by reducing the warranty terms or similar.
    Mike Hall - MVP
    > Hi JW,
    >>does
    > manual.
    > Thanks.
    >>>> Hi,
    >>>> that's what I have.
    >>>> Thanks a million.
I've got a major problem that has me stumped...! Any help will be greatly appreciated. problems?
Odd Problem. (Any help appreciated!) camaren Vista General 7 02 Jan 2009
Vista Home Basic to XP networking problem - help greatly appreciated Ged2160 Network & Sharing 3 22 Aug 2008
Sorry its another autoplay problem, but im totally stumped..... kane101 Vista General 7 25 Jul 2008
Still stumped on photo download problem t.behan Vista General 5 09 Dec 2007
Could someone please read this ANY THOUGHTS GREATLY APPRECIATED Vann Vista installation & setup 3 17 Oct 2006
