Vista - microsoft smart battery subsystem
Old 12-13-2007   #1 (permalink)
daud432
I have the problem, using legal final version of Vista Business, up-to-date
patched, on Acer aspire 1681wlmi!
There’s no battery icon or/and settings available. System information shows
“Unknown device” with detailed information “Microsoft ACPI-Compliant Embedded
Controller”, but none default driver works with this device.
Acer/microsoft has no current drivers for batteries or for Windows Vista in
general. It’s really annoying, ‘cos I don’t know how much time I have on
batteries? 20 minutes or 2 hours?
Please, correct this problem ASAP. Thanks a lot.
Old 12-13-2007   #2 (permalink)
Jupiter Jones [MVP]
Re: microsoft smart battery subsystem
"...correct this problem ASAP. Thanks a lot."
Who are you talking to?
These are peer to peer newsgroups hosted on Microsoft servers but
there is no requirement or expectation that Microsoft see any
messages.
Did the Acer come with windows Vista?
If so, it is up to Acer to ensure your drivers work properly.
If you upgraded to Windows Vista, then it is possible Acer has decided
not to furnish drivers.
Your resolution if any will have to come from Acer.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
"daud432" <daud432@xxxxxx> wrote in message
news:19F51654-0641-4DD1-8FC2-54A46C895592@xxxxxx
>up-to-date
> information shows
> Embedded
> Vista in
> have on
Driver for Smart Battery not working... Vista hardware & devices
Missing driver for Microsoft SMART Battery Vista installation & setup
VISTA "Unknown Device" = Microsoft SMART Battery Subsystem Vista hardware & devices
Microsoft SMART Battery Subsystem support in Vista Vista hardware & devices
SMART BATTERY Vista hardware & devices
Designer Media Ltd
