MAXTOR ONETOUCH III MINI EDITION External HD Problem
  1. #1
    Sudsy Guest
    I have been using this external hard drive for several months with no
    problem. This week I started receiving errors stating my back up failed.
    When I checked the system was trying to back up to D Vista Recovery Drive.
    When checking my computer-the external hard drive is not listed. I have
    checked everything I can per the instructions on the Seagate website. My
    system states the drivers are fine, everything is fine, except the external
    drive doesnt appear. I was going to unistall all of the Maxtor applications
    and reinstall. I was able to uninstall one, but I get an error when trying
    to remove Maxtor Encryption or One Touch III. It tells me to complete the
    installation. Nothing is running for this hd in processes. Any suggestions
    would be appreciated.
  2. #2
    Gary G. Little Guest
    Re: MAXTOR ONETOUCH III MINI EDITION External HD Problem
    Under Disk Drives in Device Manager, there is no listing for your Maxtor
    drive with "USB Device" appended? Under the USB controllers is there a USB
    Mass Storage Device?
    I assume you have done numerous system restarts and even powered on and off.
    If not ... try it.
    The personal opinion of
    Gary G. Little
    "Sudsy" <Sudsy@xxxxxx> wrote in message
    news:29A38843-A622-48FA-A4F7-E293BBA427FB@xxxxxx
    > external
    > applications
    > trying
    > suggestions
  3. #3
    Newbie
    Vista Home Premium 64bit
    Local Time: 09:43 PM
    I have also had problems using the Maxtor One Touch III software on a VISTA 64 bit system. The problem with drive recognition seems to have been that the registry update didn't install correctly or somehow became corrupted. The system thought that the device was already installed, so it would not re-install successfully. To solve the problem, I opened the device manager, selected the Maxtor external drive (which did show up with a yellow cirlce and exclamation point-indicating a problem with the drive) and then clicked the "uninstall" button in the device manager. I then physically disconnected the drive, re-booted the computer and then reconnected the USB connection to the Maxtor drive. This time it automatically installed the drive correctly and I am now able to see it as well as successfully read and write to it. I have not, however, been able to get the Maxtor backup software to run successfully on Vista 64 Home Premium. The Maxtor site says that their software is only good for Vista 32 bit. So for now I am using the Windows Vista backup utility and directing it to the Maxtor drive. The problem is that unlike the Maxtor backup utility, the VISTA backup files are in some special format and you can't easily explore them and cherry pick files from them. Hope this helps!
MAXTOR ONETOUCH III MINI EDITION External HD Problem problems?
HELP. Maxtor OneTouch 4 (500 GB) External Hard Drive ISSUE! Insomnia General Discussion 2 22 Jul 2009
Maxtor OneTouch III Mini Edition Jerry MAY Vista General 2 16 Mar 2008
Maxtor OneTouch III Mini Edition Jerry MAY Vista hardware & devices 0 16 Mar 2008
vista and usb maxtor onetouch mini lll laceytee Vista hardware & devices 0 30 Jul 2007
Maxtor OneTouch II Problems Yammii Vista hardware & devices 7 10 Mar 2007
