| | USB webcam disappears when hub is connected The HP Pavilion dv9565ea (nvidia chipset) laptop has a built in webcam that hangs off the USB bus. If I boot the machine connected to a 7 port (powered)usb 2.0 hub the webcam isn't listed in device manager and cannot be accessed at all. The webcam will only reappear after disappearing if the laptop is shut down and all power removed (battery out, power lead disconnected). Thereafter booting with the hub disconnected results in the webcam working. I've tried two different hubs (a cheap no brand hub and an expensive belkin hub) with the same result. Could this be a problem with vista? Any suggestions on how to further diagnose or correct this issue would be much appreciated. |
| | RE: USB webcam disappears when hub is connected Don't think its a problem with Vista, my webcam works fine running off a powered USB 2.0 hub. It may be more of a problem that the software that runs the camera is looking to the spot where the camera was hooked up to during the software setup. "drbob" wrote: Quote: > The HP Pavilion dv9565ea (nvidia chipset) laptop has a built in webcam > that hangs off the USB bus. If I boot the machine connected to a 7 port > (powered)usb 2.0 hub the webcam isn't listed in device manager and > cannot be accessed at all. > > The webcam will only reappear after disappearing if the laptop is shut > down and all power removed (battery out, power lead disconnected). > Thereafter booting with the hub disconnected results in the webcam > working. I've tried two different hubs (a cheap no brand hub and an > expensive belkin hub) with the same result. > > Could this be a problem with vista? Any suggestions on how to further > diagnose or correct this issue would be much appreciated. > |
| | Re: USB webcam disappears when hub is connected SimRacer wrote: Quote: > Don't think its a problem with Vista, my webcam works fine running off a > powered USB 2.0 hub. It may be more of a problem that the software that runs > the camera is looking to the spot where the camera was hooked up to during > the software setup. > usb port. Booting up with the hub connected causes the webcam not to appear in device manager as described in my original post. Things connected to the hub work fine. |
| | Re: USB webcam disappears when hub is connected I sometimes have to put my HP pavilion into Sleep mode to get the built in cam to work - this is the only workaround I have found. Rod "drbob" <drbob@xxxxxx> wrote in message news:Z099j.149255$Hq5.35528@xxxxxx Quote: > The HP Pavilion dv9565ea (nvidia chipset) laptop has a built in webcam > that hangs off the USB bus. If I boot the machine connected to a 7 port > (powered)usb 2.0 hub the webcam isn't listed in device manager and > cannot be accessed at all. > > The webcam will only reappear after disappearing if the laptop is shut > down and all power removed (battery out, power lead disconnected). > Thereafter booting with the hub disconnected results in the webcam > working. I've tried two different hubs (a cheap no brand hub and an > expensive belkin hub) with the same result. > > Could this be a problem with vista? Any suggestions on how to further > diagnose or correct this issue would be much appreciated. |
| Vista Home Premium 32 bit | Re: USB webcam disappears when hub is connected i have an hp dv9700t with intel chipset. I notice the same thing but only when connecting an apple USB keyboard (with a built in hub). Which uses a lot of power,perhaps the device is not activating due to a its power consumption. 1.) how much power is the USB hub using (in device manager)? 2.) how many devices are connected? |
| | #6 (permalink) |
| | Re: USB webcam disappears when hub is connected http://support.apple.com/kb/HT1216 A Apple is A Apple you need support at a Apple!!!! "awesomedarksun" <guest@xxxxxx-email.com> wrote in message news:e5852179cc35caee8f409ed8bbb53974@xxxxxx-gateway.com... Quote: > > i have an hp dv9700t with intel chipset. > > I notice the same thing but only when connecting an apple USB keyboard > (with a built in hub). Which uses a lot of power,perhaps the device is > not activating due to a its power consumption. > > 1.) how much power is the USB hub using (in device manager)? > 2.) how many devices are connected? > > > -- > awesomedarksun |
| DVD disappears (somewhat different) | Vista hardware & devices | |||
| Vista says I'm not connected to the Internet while I am connected | Vista networking & sharing | |||
| Connected to Network, but Showing NOT Connected | Vista networking & sharing | |||
| Webcam not connected error | Live Messenger | |||
| Vista VPN connected, but not connected | Vista networking & sharing | |||
