| 12-17-2007 | #1 (permalink) |
| | Lost the pop-up dialog box when microphone jack is plugged in The microphone on my headset has been working fine for a couple of months. Every time I plugged the microphone jack from the headset in the right jack of my laptop a dialog box came up with a list of items that may be used in the jack port. Microphone was first on the list and highlighted and I would click ok. Thinking I was making a shortcut for myself within this dialog box I clicked the small box to not show this again assuming microphone would then be the default. Now the dialog box does not come up as expected but the microphone no longer works. When I check hardware settings it says the microphone is working but not for me in reality. How can I get this dialog box back? |
| My System Specs |
| 01-26-2008 | #2 (permalink) |
| | Re: Lost the pop-up dialog box when microphone jack is plugged in On Dec 18 2007, 12:37*am, Cathie <Cat...@xxxxxx> wrote: Quote: > The microphone on my headset has been working fine for a couple of months.* > Every time I plugged the microphone jack from the headset in the right jack > of my laptop a dialog box came up with a list of items that may be used in > the jack port. *Microphone was first on the list and highlighted and I would > click ok. *Thinking I was making a shortcut for myself within this dialog box > I clicked the small box to not show this again assuming microphone would then > be the default. Now the dialog box does not come up as expected but the > microphone no longer works. *When I check hardware settings it says the > microphone is working but not for me in reality. How can I get this dialog > box back? |
| My System Specs |
| 04-03-2008 | #3 (permalink) |
| | Re: Lost the pop-up dialog box when microphone jack is plugged in "rk_saini@xxxxxx" wrote: Quote: > On Dec 18 2007, 12:37 am, Cathie <Cat...@xxxxxx> > wrote: Quote: > > The microphone on my headset has been working fine for a couple of months. > > Every time I plugged the microphone jack from the headset in the right jack > > of my laptop a dialog box came up with a list of items that may be used in > > the jack port. Microphone was first on the list and highlighted and I would > > click ok. Thinking I was making a shortcut for myself within this dialog box > > I clicked the small box to not show this again assuming microphone would then > > be the default. Now the dialog box does not come up as expected but the > > microphone no longer works. When I check hardware settings it says the > > microphone is working but not for me in reality. How can I get this dialog > > box back? > I am also facing the same problem.... got any solution? I got the same problem, if anyone finds a solution let me know, thanks, Rob Quote: > |
| My System Specs |
| 12-20-2009 | #4 (permalink) |
| | Re: Lost the pop-up dialog box when microphone jack is plugged in it may be too late, but if it helps, i did fix this problem with my vista system. i had the same problem, i went to the control panel, selected classic view, selected sigmatel audio settings, then i checked the box to allowed reconfiguration pop-ups. it worked for me. hope this helps. |
| My System Specs |
| Similar topics to: Lost the pop-up dialog box when microphone jack is plugged in | ||||
| Microphone doesn't work when plugged in | Vista music pictures video | |||
mic only picked up once jack removed/plugged back in | Sound & Audio | |||
| Microphone/Guitar Jack Not working | Sound & Audio | |||
| Headset plugged in front jack not working | Vista music pictures video | |||
| no audio input device discovered when microphone jack is connected | Vista music pictures video | |||
