Vista - SD card problem
Old 12-21-2007   #1 (permalink)
Nehr Tamás
SD card problem
Hy!
I've buy a Sandisk Ultra II 1 GB SD card. I put in my laptop's card reader
and I push twice by misadventure. So I unplug the card before Vista install
it properly. When I put the card in the card reader, it appears in My
Computer, but when I try to open, it says there's no disk in the drive.
I try to reinstall the driver but still doesn't work. The card is OK. It
still works in my digital camera and on other systems. The card reader is
OK. It works with other cards.
I had the same problem with my mobile phone, but I plugged into another USB
port and Vista install it again and it works. /but don't work on USB port
what I don't install my mobile phone properly before/
Thanks for your advice!
greating: Tamas
2 LAN Card Problem Network & Sharing
SD Card Problem General Discussion
2 GB sd card problem Vista hardware & devices
Tv Card Problem Media Center
SD Card Problem Vista performance & maintenance
