| | Not going to sleep Hi This has been discussed many times but my problem may be a little different After Sp1 rc computer will not automatically sleep using power options Choosing manual sleep works just fine so it´s not the usual problem with wakening computers after sleep. I have more or less changed everything but the computer wont sleep, turn off display works fine, turn of hard drive works, but no sleep. If i reboot and don´t log on sleep works... I have uninstalled AVG and Wmware since that could cause problems There is nothing an eventlog so i´m more or less stuck, what to do next? Any more logs to check ? I'm using vista ultimate x64 sp1 rc, asus p5k motherboard and nvidia 8600 with latest drivers. I can send more info on request.. /Bjorn |
| Vista won't go to sleep, or will come out of sleep | Vista hardware & devices | |||
| Sleep Mode - disconnected, automatically reconnected after sleep m | Vista networking & sharing | |||
| Sleep mode - Computer does not got to sleep | Vista General | |||
| No Auto Sleep - Manual Sleep OK | Vista General | |||
| Goes to sleep after returning from sleep | Vista General | |||
