| | Distorted sound after installing Vista Home Premium I just installed Vista Home Premium onto my pc, and everything seems to be running ok, except for the sound. No matter what application I run, my sound seems to skip a lot. It's most noticeable when listening to music or TV. Various media players don't make a difference, and it acts like my pc is starving for resources. I've got a 3.2Ghz cpu w/2Gb of memory and plenty of hard drive space. 256Mb ATI video card, and Audigy sound card, but it looks like Vista makes the applications run off of the virtual memory, even when nothing else is running. Is anyone having issues like this? Any suggestions? I've disabled services and features till I'm blue in the face. Nothing seems to help, although increasing CPU priority for the process seems to make it better, but it's still skipping. Thanks, |
| | Re: Distorted sound after installing Vista Home Premium Have you updated the audio driver? You don't say which Audigy audio device you have. "Tracy W." <TracyW@xxxxxx> wrote in message news:26B5F6F3-7BE9-497E-AEA9-EB2003D6F874@xxxxxx Quote: >I just installed Vista Home Premium onto my pc, and everything seems to be > running ok, except for the sound. No matter what application I run, my > sound > seems to skip a lot. It's most noticeable when listening to music or TV. > Various media players don't make a difference, and it acts like my pc is > starving for resources. I've got a 3.2Ghz cpu w/2Gb of memory and plenty > of > hard drive space. 256Mb ATI video card, and Audigy sound card, but it > looks > like Vista makes the applications run off of the virtual memory, even when > nothing else is running. Is anyone having issues like this? Any > suggestions? I've disabled services and features till I'm blue in the > face. > Nothing seems to help, although increasing CPU priority for the process > seems > to make it better, but it's still skipping. > > Thanks, > |
| | Re: Distorted sound after installing Vista Home Premium Check to be sure you have the latest Sound Drivers for Vista. Try disabling ALL enhancements, see the Section "How does loudness equalization work?" "Tracy W." <TracyW@xxxxxx> wrote in message news:26B5F6F3-7BE9-497E-AEA9-EB2003D6F874@xxxxxx Quote: >I just installed Vista Home Premium onto my pc, and everything seems to be > running ok, except for the sound. No matter what application I run, my > sound > seems to skip a lot. It's most noticeable when listening to music or TV. > Various media players don't make a difference, and it acts like my pc is > starving for resources. I've got a 3.2Ghz cpu w/2Gb of memory and plenty > of > hard drive space. 256Mb ATI video card, and Audigy sound card, but it > looks > like Vista makes the applications run off of the virtual memory, even when > nothing else is running. Is anyone having issues like this? Any > suggestions? I've disabled services and features till I'm blue in the > face. > Nothing seems to help, although increasing CPU priority for the process > seems > to make it better, but it's still skipping. > > Thanks, > |
| | Re: Distorted sound after installing Vista Home Premium I had installed a Sound Blaster X-Fi Extreme Gamer card with the latest drivers, but no change. I also upgraded my CPU from the 3.2Ghz single-core to a 2.2Ghz Dual Core. It helped, but I still get the skips. I blew it all away over the weekend, and reinstalled Vista. The issue is better, but it still skips, especially when I'm trying to run any other application, like IE or email. I didn't put the SB card in this time, so I'm on the Realtek HD Audio card which is built into the M/B. I have the latest drivers from Realtek, but it's still skipping. Very frustrating to say the least. It acts like it's resource related, but it has plenty of resources. CPU is not busy at all, hard drives are good, plenty of memory, etc.... It's an ASRock M/B which is rated for Vista, so I'm at a loss. "Spirit" wrote: Quote: > Check to be sure you have the latest Sound Drivers for Vista. > > Try disabling ALL enhancements, see the Section "How does loudness > equalization work?" > > > "Tracy W." <TracyW@xxxxxx> wrote in message > news:26B5F6F3-7BE9-497E-AEA9-EB2003D6F874@xxxxxx Quote: > >I just installed Vista Home Premium onto my pc, and everything seems to be > > running ok, except for the sound. No matter what application I run, my > > sound > > seems to skip a lot. It's most noticeable when listening to music or TV. > > Various media players don't make a difference, and it acts like my pc is > > starving for resources. I've got a 3.2Ghz cpu w/2Gb of memory and plenty > > of > > hard drive space. 256Mb ATI video card, and Audigy sound card, but it > > looks > > like Vista makes the applications run off of the virtual memory, even when > > nothing else is running. Is anyone having issues like this? Any > > suggestions? I've disabled services and features till I'm blue in the > > face. > > Nothing seems to help, although increasing CPU priority for the process > > seems > > to make it better, but it's still skipping. > > > > Thanks, > > > > |
| Vista Ultimate x64 | Re: Distorted sound after installing Vista Home Premium I would suggest updating your codecs go through all the settings in control panel/sounds and the realtek options as well, you may need to play around with them a bit to get find the best settings. Also you may need to adjust your bios settings and possibly modify the resources available for your sound device. And make sure that you do a regular disk defrag |
| | #6 (permalink) |
| | Re: Distorted sound after installing Vista Home Premium Actually, I was able to resolve it last night. Turns out to be the RAID driver for my VIA RAID controller. I had the latest version installed (which was supposed to support Vista), but I un-installed it and went back to the version I used with Win2k, and it solved the problem. This was the most expensive troubleshooting job I've gone through, but the PC sure screams now, w/o stuttering! Thanks for all of the suggestions. "Wild" wrote: Quote: > > I would suggest updating your codecs go through all the settings in > control panel/sounds and the realtek options as well, you may need to > play around with them a bit to get find the best settings. > Also you may need to adjust your bios settings and possibly modify the > resources available for your sound device. > > And make sure that you do a regular disk defrag > > > -- > Wild > |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
| vista 64 home premium no sound | Media Center | |||
| Installing new Vista Home Premium OEM | Vista installation & setup | |||
| Installing Vista Home basic with Home Premium DVD | Vista General | |||
| Installing VPC on Vista Home Premium | Vista installation & setup | |||
