| | Maximum port speed for standard modem need to be increased I'm using 3g phone to connect to the internet. Using standard modem over Bluetooth link as a driver, the speed is not as expected since the maximum speed that can be setup in driver properties is 115.2 kbs while the speed offered by 3g network is 384 kbs. So, I hope Microsoft can resolve this problem. ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...rdware_devices |
| | RE: Maximum port speed for standard modem need to be increased "blackhornetx" wrote: Quote: > I'm using 3g phone to connect to the internet. Using standard modem over > Bluetooth link as a driver, the speed is not as expected since the maximum > speed that can be setup in driver properties is 115.2 kbs while the speed > offered by 3g network is 384 kbs. So, I hope Microsoft can resolve this > problem. > > ---------------- > This post is a suggestion for Microsoft, and Microsoft responds to the > suggestions with the most votes. To vote for this suggestion, click the "I > Agree" button in the message pane. If you do not see the button, follow this > link to open the suggestion in the Microsoft Web-based Newsreader and then > click "I Agree" in the message pane. > > http://windowshelp.microsoft.com/com...rdware_devices |
| | Re: Maximum port speed for standard modem need to be increased It appears that you are limited to the speed of your Standard Modem since no signal can go faster through it "MaNimal" <MaNimal@xxxxxx> wrote in message news:BF59514F-E889-4152-8D85-755D82D687F4@xxxxxx Quote: > > > "blackhornetx" wrote: > Quote: >> I'm using 3g phone to connect to the internet. Using standard modem over >> Bluetooth link as a driver, the speed is not as expected since the >> maximum >> speed that can be setup in driver properties is 115.2 kbs while the speed >> offered by 3g network is 384 kbs. So, I hope Microsoft can resolve this >> problem. >> >> ---------------- >> This post is a suggestion for Microsoft, and Microsoft responds to the >> suggestions with the most votes. To vote for this suggestion, click the >> "I >> Agree" button in the message pane. If you do not see the button, follow >> this >> link to open the suggestion in the Microsoft Web-based Newsreader and >> then >> click "I Agree" in the message pane. >> >> http://windowshelp.microsoft.com/com...rdware_devices |
| | RE: Maximum port speed for standard modem need to be increased I found this (your) post whilst searching for a solution to the same limitation in Windows XP, & therefore whole heartedly agree with your suggestion. Similarly, I use a high speed 3.5G mobile [HSDPA(high speed data packet access)] connection over a Nokia mobile, linked to my PC via USB, and found the same problem. Depending on OS and/or mobile phone driver version, it seems that the maximum port speed (baud rate) can vary, at intervals, from 115200 (or possibly lower) to 460800 or 921600, but no higher... [found through modem options in control panel] Interetingly though, it doesn't necessarily seem to actually limit the data transfer rate whilst the connection is in use, at least in my case, as it would often test far higher (using various reliable broadband speed testing websites) if any higher speed is available on the mobile network at that time! [Connection speeds over mobile networks are dependent on many more 'real world' factors and is beyond the scope of this reply, but worth investigating...] Perhaps the 'real' (actual) data rate you can obtain is mainly determined by the transmitters, receivers (nodes) and servers of such a network? For example, the 3 Mobile Network is theoretically capable of a maximum connection of 2.5-3Mbps (under the most ideal conditions, when extremely quiet), and it is only possible to get close to these speeds at certain (unsociable) times of day..! Far more importantly, it appears [after much research] that configuring protocol & packet settings are far more important to maintain an efficient, and thus higher speed connection. Plenty of information can be found on the web as to the best ways to 'tweak' these settings manually for increased speed without adversely affecting transfer integrity, or a small number of free or trial connection configuration software utilities/tools can be downloaded here & there to do just this. [One I would recommend is 'TZ Connection Booster' as it sets all these variables according to the type of connection you specify, whilst also explaining & guiding you through during setup...] Furthermore, one always has the option of using a connection 'booster' that simply limits the amount & type of information downloaded during the page loading process, or even a simple ad-blocker, etc, etc...but I digress. So back to the original point, if it indeed matters now; surely it would be a simple thing for someone kind enough at Microsoft to take the time to patch their generic drivers or code in a simple registry edit for all of us Vista & XP users in need out here, in a world of rapidly increasing mobile data network capabilities, so that we can at least have the option of setting/choosing our maximum modem port speed in line with the speeds that are currently available.!? Hopefully 'they're' not going to say 'it's not our problem', that it is up to each individual mobile phone network or manufacturer to all improve their drivers, as they're all probably (with luck) making use of Microsofts own generic modem drivers..? Fixing this one small thing, with such a large scope, may even improve customer satisfaction a little... We live in hope! |
| | Re: Maximum port speed for standard modem need to be increased In response to Curious; Each modem has its' own maximum speed capability, hence the different types, of which there are many. Only if a particular modem had managed to be installed with a driver that limited it in some way like this (perhaps outdated) would it be prevented from transmitting/receiving at it's rated speed, or if the only driver available was a default generic one within the OS. [Though this seems to be highly unusual, as mobile phone manufacturers provide drivers to users after writing them in conjunction with the makers of the OS', and would be wanting their products to be able to be utilized fully...] Kind of like there only being an older person available to, but who is incapable of, driving a fast car to its fullest... |
| | #6 (permalink) |
| | Re: Maximum port speed for standard modem need to be increased You're confusing two different connections. Your phone can be used as a standard dial-up modem when used in areas where there is no data connection available. Believe it or not, there are still such places, especially if you live outside major metropolitan areas. :-) When in use as a data pump (connected via USB and using whatever utility your phone bundles to access the data network) the serial port is not in use. So it doesn't matter what you set it to, you are using the virtual port created by the phone's data pump manufacturer, not a real serial port. The data speed is irrelevant. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "MaNimal" <MaNimal@xxxxxx> wrote in message news:F5A1D870-9937-44E1-A5D4-C500F1D7FC58@xxxxxx Quote: >I found this (your) post whilst searching for a solution to the same > limitation in Windows XP, & therefore whole heartedly agree with your > suggestion. |
| Standard RS-232 modem driver / RAS troubles | Vista hardware & devices | |||
| Allow Standard User to Change Maximum Port Speed in Vista | Vista General | |||
| User right for change Maximum port speed | Vista account administration | |||
| Modem speed is half | Vista networking & sharing | |||
| Com port for modem? | Vista installation & setup | |||
