| | Vista - HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. |
| 12-27-2007 | #1 |
| | HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. My Sony Vaio (Windows Vista Home Premium) is stuck in "Logging off" mode. No matter what I do, Windows keeps resuming where it left off, which is apparently in Logging Off mode. Any suggestions would be greatly appreciated!!!! |
| My System Specs |
| 12-27-2007 | #2 |
| Vista Ultimate X64 | Re: HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. Hi Jamsaz, I would try a check disk on the PC. The link below tells you how to do it. http://www.vistax64.com/tutorials/67...isk.html?ltr=C Raj |
| My System Specs |
| 12-27-2007 | #3 |
| | Re: HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. Hi, Jamsaz. How long have you let it continue "logging off"? It probably needs to "put away its toys", close all the open applications and other files, then log off your account. Then it can move on to "Shutting Down". Usually logging off takes less than a minute, but sometimes it takes a lot longer - mine has taken over 20 minutes sometimes. Recently, I've started closing all applications myself, then giving Vista a few minutes before clicking Shut Down. Now it usually powers off in less than a minute. ;<) Are you the only logged-on user? Is your Sony new? The computer probably is not defective, but if it is, you should be able to get it fixed or replaced under warranty. RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2008 in Vista Ultimate x64) "jamsaz" <jamsaz@xxxxxx> wrote in message news:2812E039-E406-48B3-8625-79ABDC6B4199@xxxxxx Quote: > My Sony Vaio (Windows Vista Home Premium) is stuck in "Logging off" mode. > No > matter what I do, Windows keeps resuming where it left off, which is > apparently in Logging Off mode. Any suggestions would be greatly > appreciated!!!! |
| My System Specs |
| 01-21-2008 | #4 |
| | Re: HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. I got the same problem with my Gateway, using Windows Vista Home Premium too. after 12 hours of "logging off", I finally solved the problem by removing the battery, without the power cord attached. I guess this resets everything and I was able to boot again. -- ggagnon ------------------------------------------------------------------------ ggagnon's Profile: http://forums.techarena.in/member.php?userid=40008 View this thread: http://forums.techarena.in/showthread.php?t=879173 http://forums.techarena.in |
| My System Specs |
| 03-16-2008 | #5 |
| | Re: HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. Thank you ggagnon! My daughter had this prob;em and we followed your advice and it worked fine. "ggagnon" wrote: Quote: > > I got the same problem with my Gateway, using Windows Vista Home Premium > too. after 12 hours of "logging off", I finally solved the problem by > removing the battery, without the power cord attached. I guess this > resets everything and I was able to boot again. > > > -- > ggagnon > ------------------------------------------------------------------------ > ggagnon's Profile: http://forums.techarena.in/member.php?userid=40008 > View this thread: http://forums.techarena.in/showthread.php?t=879173 > > http://forums.techarena.in > > |
| My System Specs |
| Similar Threads for: HELP....my Sony Vaio is stuck in "LOGGING OFF" mode. | ||||
| Vista stuck on "logging off" | General Discussion | |||
| RE: virtual machine is stuck in "turning off" mode | Virtual Server | |||
| Stuck in "Start Up Repair" mode | Vista General | |||
| STUCK IN "LOGGING OFF" MODE.....help! | Vista General | |||
| FIX FOR "Windows Explorer has stopped worked" on Sony Vaio Laptops running Vista | Vista General | |||
