Vista - Parallel to USB Cable Installation
Old 12-29-2007   #1 (permalink)
phil allen
I am trying to use a SYBA USB to Parallel Cable to support my Color LaserJet
5 printer underVISTA. I checked SYNA and they stated support for only SPP
mode but don't know where to change to SPP mode. Also, is there a special
driver to change theinterface from Parallel to USB?
I also tried using the installed Manhattan Parallel Port card but the result
is always the same - data is loaded into the printer and then disappears
without printing and no errors.
Old 12-29-2007   #2 (permalink)
Wandering
Re: Parallel to USB Cable Installation
You are going to have to install Vista drivers for that printer. It's old
enough I don't know if there are any. Visit the HP site, and look for Vista
drivers for that model.
The converter may - I have no experience with such a beast - also require
Vista drivers.
Good luck
"phil allen" <philallen@xxxxxx> wrote in message
news:F12605E9-A6F6-49A8-8D47-05EC91ED2233@xxxxxx
>LaserJet
> result
Old 01-01-2008   #3 (permalink)
Patrick
you should be able to set the SPP mode, in your Bios for LPT settings.
"Wandering" <amore.dei@xxxxxx> wrote in message
news:uU3IbCmSIHA.1204@xxxxxx
> Vista drivers for that model.
> Vista drivers.
> Good luck
>>LaserJet
>> SPP
>> special
>> result
Old 03-10-2008   #4 (permalink)
Bill Loudon
Hi, I hope some of you guys are still watching this theme.
Can anyone tell me if there is a driver needed for a Parallel to usb cable
(from printer to pc)? I have a vista OS.
Many thanks Bill
> > Vista drivers.
> > Good luck
> >>LaserJet
> >> SPP
> >> special
> >> result
Old 03-10-2008   #5 (permalink)
jimrx4
I have an older HP LaserJet 2100xi that uses a parallel port. I bought a USB
to Parallel adapter (from Belken I think), connected it to my HP printer and
it worked with no additional drivers. It recognized my printer immediately
and worked - with one caveat. When I would print a document the first page
seem to come out with garbage but the subsequent pages printed fine with no
loss of data.
"Bill Loudon" <BillLoudon@xxxxxx> wrote in message
news:33DA3D56-DAF2-42F3-8BE7-423698BC2A5A@xxxxxx
> Many thanks Bill
>> > old
>> > require
>> > Vista drivers.
>> > Good luck
>> >>LaserJet
>> >> SPP
>> >> special
>> >> result
>> >> disappears
Need to create a parallel installation of Windows NT but no boot CD Vista General
USB to Parallel cables: A defective cable story Vista print fax & scan
Parallel installation of VC6, VS2003 and VS2008 .NET General
USB-to-parallel cable Vista print fax & scan
Looking for a USB to parallel por cable with a Vista compatible dr Vista hardware & devices
