Vista - System Volume Information
Old 12-31-2007   #1 (permalink)
Vista Ultimate x32
I find that I have over 305GB tied up in the folder for System Volume Information. I believe it is used for system restores but this is ridiculous. Any suggestions on how to purge it without impacting my system which is Vista Ultimate?
Last edited by jmjprince; 12-31-2007 at 05:18 PM.. Reason: Found the answer under disk clean up
Old 12-31-2007   #2 (permalink)
Colin Barnhorst
Re: System Volume Information
How large is the drive? NTFS should be using about 15%.
"jmjprince" <jmjprince.32h875@xxxxxx-mx.forums.net> wrote in message
news:jmjprince.32h875@xxxxxx-mx.forums.net...
> jmjprince
Old 12-31-2007   #3 (permalink)
Vista Ultimate x32
It is a 450GB drive. I figured out how to clean out the old restore points under Disk Cleanup/More Options.
Thanks.
Old 01-01-2008   #4 (permalink)
BurrWalnut
Rather than have just one system restore point why don’t you allocate a
finite amount of space to it. To reduce the amount of space, open an elevated
command prompt by clicking the Windows Orb (Start) > All Programs >
Accessories and right-click Command Prompt, then ‘Run as Administrator’.
To display the current parameters type (or copy and paste) “vssadmin list
shadowstorage” (not the quotes but the spaces) and press Enter.
To reduce (or increase) the disk space allocated, type (or copy and paste)
“vssadmin resize shadowstorage /on=c: /for=c: /maxsize=3GB” (not the quotes
but the spaces) and press Enter. This example assumes changing the space on
drive C to 3GB.
You may find that all the restore points have been removed after resizing so
make sure the computer is behaving itself before reducing the space
allocation. Also, make a manual restore point immediately after resizing.
> Thanks.
> jmjprince
43 GB System File in System Volume Information on 160 GB partition Vista General
Get rid of System Volume Information Vista file management
System Volume Information Vista performance & maintenance
system volume information? What is it? Vista General
Designer Media Ltd
