im haven a problem with my second hard drive the problem is it dont show up
on vista. i had window min, both drive was working fine. i format both drive
only one work but the other dont any suggestions?
i was running on windows Millennium and both hard drive was working
fine...yeah i checked, its not in BIOS. I did almost everything but then when
i tryed it in another computer the drive work fine but the outer computer is
running on windows xp. I format the drive in ms dos.... D: format
"Malke" wrote:
> thi wrote:>
> I don't know what "window min" means, but:
> 1. Check if the drive shows in the BIOS.
> Accessing the BIOS
> http://michaelstevenstech.com/bios_manufacturer.htm
> http://www.uktsupport.co.uk/reference/biosp.htm
> http://www.computerhope.com/issues/ch000235.htm
> 2. If it doesn't show, check your jumpering (assuming an IDE drive).
> Find jumpering details for the drive on the drive mftr.'s tech support
> website. Also check your cabling.
> 3. How did you format the drive? Does it show up in Disk Management
> (Administrative Tools in Control Panel)?
> Malke
> Elephant Boy Computers
> www.elephantboycomputers.com
> "Don't Panic!"
> MS-MVP Windows - Shell/User
Is it an IDE or SATA drive?
thi wrote:If the drive works in another computer, then you know the drive is still
good. Therefore the problem must lie in the way you've installed it in
the upgraded computer. As I said, check jumpering - on *both* drives
since some drives require a different jumpering for Master-with-slave
than they do for just Master/Single. Also you might try a different IDE
cable, making sure it is 80-pin and not the old 40-pin.
Other than that, you might consider having someone knowledgeable take a
look since it will be rather difficult to diagnose what you are doing
wrong without actually seeing the computer.
Malke
"Don't Panic!"
thanks for the input!!! i will sure do that this weekend
"Malke" wrote:
> thi wrote:>
> Malke
> "Don't Panic!"
| Similar Threads | ||||
| Hard Drive Problem? | PsychoUsagi | Vista General | 1 | 20 Jun 2009 |
| Problem with Hard drive! | fields999 | Drivers | 8 | 28 Mar 2009 |
| Hard Drive Problem | Smoggie | Vista hardware & devices | 4 | 18 Feb 2009 |
| Hard drive problem | Ronin | Vista General | 2 | 06 Feb 2008 |
| Hard Drive Problem | S Murder | Vista hardware & devices | 4 | 21 Oct 2007 |
