Vista - Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help!
Old 01-21-2008   #11 (permalink)
Vista Premium 32bit
Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help
Well, Microsoft rang me back...
Apparently this is one of the one in 200 problems for which Microsoft have no solution.
The only way to get it to work is to re-install the OS. Decided to use it with my work computer instead!! Works fine on Vista on this one!
So I suppose that concludes it... Microsoft can't fix it.
Authentec update causes Fingerprint reader to no longer work Vista hardware & devices
Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint reader does not work Vista General
Fingerprint Reader Vista hardware & devices
Intellimouse Explorer 4.0 wheel double-click doesn't work Vista General
MS Wireless Intellimouse Model 1007 won't work Vista General
