| Guest | Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Hi group, I am trying to get the Fingerprint Reader to work, but no luck! When I start the "Fingerprint registration wizard', I get the following message: "Error Invalid class string. Suspect installation problem." I have un-installed, re-installed at least 10times. no luck. I got the newest software from MicroSoft, DPPM_201_ENG.exe. (it says: VISTA Compatible).Mouse works just fine. I googled for an answer, I found the same problem that others also have, but nobody had an answer. I installed also under Windows XP, there it works perfectly with the same installation software. Checked at the MS-knowledge base, fix recommendations are more than 2 years old, tried it anyway, still no luck. Changed USB ports, ran it as Windows XP compatible, tried really everything, I am really at a loss. Hopefully someone out there has/had the same problem and got it working? After 2 days of trying I'm really getting..., well you know what I mean! -- Just be happy and keep on smiling! Regards Pete |
| Guest | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Hi Dwarf, Thanks alot for your fast response, but the mouse ist working O.K. I already had IP32Eng6.20.182.0.exe installed. It's the printreader that refuses to work. Thank you for trying to help. Pete "Pete" <petgol@xxxxxx> wrote in message news:477e4d2f$0$16586$9b4e6d93@xxxxxx-online.net... Quote: > Hi group, > I am trying to get the Fingerprint Reader to work, but no luck! > When I start the "Fingerprint registration wizard', I get the following > message: > "Error Invalid class string. Suspect installation problem." I have > un-installed, re-installed at least 10times. no luck. > I got the newest software from MicroSoft, DPPM_201_ENG.exe. (it says: > VISTA Compatible).Mouse works just fine. I googled for an answer, I found > the same problem that others also have, but nobody had an answer. I > installed also under Windows XP, there it works perfectly with the same > installation software. > Checked at the MS-knowledge base, fix recommendations are more than 2 > years old, tried it anyway, still no luck. Changed USB ports, ran it as > Windows XP compatible, tried really everything, I am really at a loss. > Hopefully someone out there has/had the same problem and got it working? > After 2 days of trying I'm really getting..., well you know what I mean! > -- > Just be happy and keep on smiling! > Regards > Pete > |
| Guest | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will no I'm having the same problem as Dwarf |
| Member | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help I have the same problem but with just the Fingerprint reader. Nobody seems to have a solution! I've tried everything now! |
| Guest | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Is there really noone in this whole wide world that could help, with this problem? Not even a response from Microsoft or a MS-affiliate or MS-MVP ? Really sad! Quote: > Hi group, > I am trying to get the Fingerprint Reader to work, but no luck! > When I start the "Fingerprint registration wizard', I get the following > message: > "Error Invalid class string. Suspect installation problem." I have > un-installed, re-installed at least 10times. no luck. > I got the newest software from MicroSoft, DPPM_201_ENG.exe. (it says: > VISTA Compatible).Mouse works just fine. I googled for an answer, I found > the same problem that others also have, but nobody had an answer. I > installed also under Windows XP, there it works perfectly with the same > installation software. > Checked at the MS-knowledge base, fix recommendations are more than 2 > years old, tried it anyway, still no luck. Changed USB ports, ran it as > Windows XP compatible, tried really everything, I am really at a loss. > Hopefully someone out there has/had the same problem and got it working? > After 2 days of trying I'm really getting..., well you know what I mean! > -- > Just be happy and keep on smiling! > Regards > Pete > |
| | #6 (permalink) |
| Member | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help I was going to call Microsoft on Monday. Has anyone else tried to contact them? Digital Persona's website says support is provided by Microsoft. |
| | #7 (permalink) |
| Guest | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! I have used Microsoft Product Support Services by phone and email many times and have always been pleased with the service and the resolutions to my problems. "renegade78" <renegade78.334mk3@xxxxxx-mx.forums.net> wrote in message news:renegade78.334mk3@xxxxxx-mx.forums.net... Quote: > > I was going to call Microsoft on Monday. Has anyone else tried to > contact them? > > Digital Persona's website says support is provided by Microsoft. > > > -- > renegade78 |
| | #8 (permalink) |
| Member | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help Sorry, I meant had anybody rung them with this specific problem. |
| | #9 (permalink) |
| Member | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help I phoned Microsoft. They suggested I add a new user account and re-install. I did this; it didn't work! I have now been escalated and will be contacted in 3 days! |
| | #10 (permalink) |
| Guest | Re: Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Hi Renegade, I also tried that with a new user account and re-installed, like you said, it didn't work. Please let me know if MS came up with a brain storm for a fix. Thanks. ************************** There's always a light at the end of a tunnel ! Long live Clem Kadiddlehopper !!! Regards Pete ************************** "renegade78" <renegade78.33a1p3@xxxxxx-mx.forums.net> wrote in message news:renegade78.33a1p3@xxxxxx-mx.forums.net... Quote: > > I phoned Microsoft. > > They suggested I add a new user account and re-install. I did this; it > didn't work! > > I have now been escalated and will be contacted in 3 days! > > > -- > renegade78 |
| Authentec update causes Fingerprint reader to no longer work | Vista hardware & devices | |||
| Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint reader does not work | Vista General | |||
| Fingerprint Reader | Vista hardware & devices | |||
| Intellimouse Explorer 4.0 wheel double-click doesn't work | Vista General | |||
| MS Wireless Intellimouse Model 1007 won't work | Vista General | |||
