Vista Tutorial - Re: No sound - red light in headphone jack
Old 01-05-2008   #1 (permalink)
Colin Barnhorst
Guest
You need to say what model laptop you have and what audio adaptor it has.
XP drivers will not help. If the manufacturer's website does not have Vista
drivers for your laptop then Vista is not supported on it and you should use
your restore cd to return to your previous OS.
"Visceral" <Visceral@xxxxxx> wrote in message
news:BF562463-DE35-45A6-AEFD-9CD6F810FA93@xxxxxx
Quote:
> Hello.
> I have a laptop with Vista on it. It is a hand-me-down from another in my
> family. When I got it, I naturally wanted a clean slate, so I wiped the
> hard
> drive and reinstalled everything. Ever since, I have been getting no
> sound
> out of either the speakers or the headphone jack, and their is this little
> red light shining out of the headphone jack. I have reinstalled all my
> drivers, to some success. While the red light went away, there was still
> no
> sound, and then some of my programs did not work. I therefore restored it
> back to before I reinstalled the drivers. I have read that the light
> probably has something to do with the SPDIF outlet, so I disabled that
> device. However, the red light remains. I have done everything I can
> think
> of to fix this computer, but none of it works! Does anyone know of
> anything
> that I have not already tried?
> -Thanks
Old 01-05-2008   #2 (permalink)
Visceral
Guest
My computer is a MS-1633X, the type is X86. It was manufactured for
Cyberpower PC by the Micro-Star Corporation. This computer came with Vista,
I did not upgrade it. The computer is designed as a Vista-compatible PC.
Quote:
> > Hello.
> > hard
> > sound
> > no
> > think
> > anything
> > -Thanks
Old 01-05-2008   #3 (permalink)
Colin Barnhorst
Guest
I have had reasonable luck talking to CyberPower's tech support (both by
email and by phone) on both the computers I bought from them. What is
support telling you about this issue? I can't find "MS-1633X" or
"MSI-1633X" on the MSI website and the CyberPower website does not have a
search feature so I can't tell what adaptor you have.
news:2B291E53-0546-4922-8AA5-F72129EF7583@xxxxxx
> Vista,
>> Vista
>> use
Quote:
>> > Hello.
>> > my
>> > the
>> > hard
>> > sound
>> > little
>> > still
>> > no
>> > it
>> > think
>> > anything
>> > -Thanks
Headphone jack Not working!!! Sound & Audio
Headphone Jack?? Sound & Audio
No Sound Through Headphone Jack Vista General
Realtek only sees headphone jack?? Vista hardware & devices
Headphone jack doesn't work Vista hardware & devices
