Vista - Setting Default Printer to Stay
Old 01-08-2008   #1 (permalink)
LMI
I have a new user in which i just finished configuring Vista Business edition
inside a SBS 2003 network. I tried to set my default printer however each
time i set it and have the user log off it revert back to the windows xps
writter. If i delete this it will defaul to the next printer. How can i save
my setting changes in Vista?
Vista - default printer doesn't stay as default Vista print fax & scan
Setting a default printer for the DEFAULT USER Vista print fax & scan
Vista machine not holding default printer setting. Vista print fax & scan
Problem setting default printer in Vista Vista General
Setting default printer Vista installation & setup
