Vista - Samsung phone (external USB drive) not really working..... why?
Old 01-11-2008   #1 (permalink)
Vista Ultimate 32bit
Hello.
I have a Samsung SCH-F679 CDMA phone with a Micro-SD memory card slot. In there i have a 2GB Micro-SD which works just excellent.
When i hook that phone up to a XP Computer and chose "connect to PC" in the phone menu (which basically disables the phone, making it a "thumb drive") it is correctly detected as an "external drive" and i can access it fine thru "My Computer", see all folders on the Micro-SD card and can drag/drop or copy/paste as well as delete files.
Not so in Vista, teste don my own Ultimate 32bit as well as a coleagues Home Premium (i believe 32bit as well).
There it too detects the "external drive" but comes up with "The disk in drive N: (or whatever drive letter assigned) has to be formatted before you can continue. Do you want to format it now?" I have once tested if i CAN actually format it - it fails with "error: access is denied". In a card reader that card shows up as a regular FAT32-formatted 2 GB memory card without any problems (it was formatted by the phone, even first formatting it with the PC yields no success - same result).
What can i do to make this work as it does under XP? It is kind of stupid having to take out the memory card and search for the adaptor thingy to use the internal card reader on the PC each time i want to upload an mp3 or picture when i HAVE the data cable for the phone (and no, there is no Vista-compatible software suite from Samsung yet available, either).
Appreciate any help.......
your Thanh
Optical DVD drive quits working and external DVD drive not accessible Vista hardware & devices
Using my Data Cable for my Mobile Phone (Samsung D840) Vista installation & setup
Cannot Sync Samsung Phone with PDA to Palm Desktop with Vista Vista installation & setup
Cannot Sync Samsung Phone with PDA to Palm Desktop with Vista Vista hardware & devices
weird network problem after attaching my samsung blackjack phone Vista networking & sharing
