Vista - Standby lasts for a short period after which the system resumes
Old 07-25-2006   #1 (permalink)
=?Utf-8?B?Q29uYWw=?=
After selecting standby, the system goes into standby mode for a few seconds
and then awakes. The event logs reveal that the system was awakened by the
usb root hub. The power settings on the usb root hubs do not have the allow
device to awake frtom standby checked. Is there another setting somewhere
where I can force wake-up from specified devices i.e. keyboard only?
Old 07-27-2006   #2 (permalink)
=?Utf-8?B?cGlwcGlu?=
RE: Standby lasts for a short period after which the system resumes
My keyboard worked this way after install even without any drivers.
Check under device manager for your keyboard and enable the bring out of
sleep from there.
I had a USB root hub error in my logs which indicated the hub preventing
sleep yet mine does sleep and the keyboard will bring me back again.
I wasn't sure then if I should be using sleep in case I my monitor or
something in the root hub would stop working. I liked sleep mode when I was
leaving the computer for a while but this bit worried me.
I will check my settings later but know my keyboard and not the mouse
brought me back to the desktop without me having to configure anything.
I would like to use sleep again as it worked fro me. The keyboard I am
using for Vista is not even a really fancy one!
Mouse Does not work after the system resumes from sleep General Discussion
required certificate is not within its validity period when verifyingagainst the current system clock... Vista General
System will not enter standby. Ideas? Vista General
Installation/Running period problems, check my system for known in Vista hardware & devices
