Vista Tutorial - Monitor loses signal while in sleep mode
Old 01-11-2008   #1 (permalink)
Cheryl
Guest
Anybody know why my lcd screen would lose signal while the computer is in
sleep mode (sleep, not hibernation or any of the other options)? If I put
the system in sleep mode, I have to reboot my system in order for my monitor
to receive signal again. I have an acer 2223w and an Asus M2A-VM
motherboard. Don't know if it has anything to do with a setting in the
motherboard, or if it is the monitor. I'm also running Vista. I've
downloaded the most recent drivers.
Old 01-11-2008   #2 (permalink)
John
Guest
Re: Monitor loses signal while in sleep mode
"Cheryl" <Cheryl@xxxxxx> wrote in message
news:A2784FA7-CA46-4DCF-B5F2-583F9E37C12B@xxxxxx
> monitor
Most likely your video card is not being re-initialized when the
computer comes out of sleep mode. Thus it doesn't send any
video to the monitor. Check the video card manufacturer
for updated video rivers.
Old 01-11-2008   #3 (permalink)
Cheryl
Guest
I have integrated video on the motherboard. We've updated the drivers
lately. Do I still need a separate video card or is this sufficient?
Thanks for the reply.
> > monitor
Old 01-12-2008   #4 (permalink)
John
Guest
news:A48EB4FA-EC81-489A-ACC6-53E0C8440302@xxxxxx
In that case the video drivers would be supplied by the
motherboard manufacturer. You do not need a seperate
video card unless you want more video capability than
the onboard video provides. I would not use video
drivers from the video chipset manufacturer since
they don't know what additional control hardware
the motherboard manufacturer may have included
on the motherboard. All of the drivers for
motherboard hardware should come from the
PC Comes out of Sleep Mode, but not Monitor General Discussion
monitor sleep mode General Discussion
Monitor Loses signal on boot up Vista hardware & devices
Monitor in sleep mode Vista General
4 screens on one monitor and monitor won't wake up from sleep mode Vista hardware & devices
