Vista - Built in Webcam HELP
Old 01-13-2008   #1 (permalink)
Erin
I upgraded to Vista a while back, and since then I can not access my webcam.
The only option is to uninstall it. I have downloaded all drivers, but I
still can't access it. It is a built in webcam for HP Pavilion dv2000. Any
help or advice would be greatly appreciated.
Thanks!
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
http://windowshelp.microsoft.com/com...rdware_devices
Old 01-13-2008   #2 (permalink)
Colin Barnhorst
Re: Built in Webcam HELP
HP has firmware updates the webcam for Vista on their website.
"Erin" <Erin@xxxxxx> wrote in message
news:E9BF026A-2B23-4F07-B5E2-ACF7AE7649D8@xxxxxx
>webcam.
> Thanks!
> this
Old 01-14-2008   #3 (permalink)
Erin
The thing is that I have downloaded all of that.. and, still, I am not able
to access the webcam. I only have the option to uninstall.
> >webcam.
> > Thanks!
> > this
Old 01-16-2008   #4 (permalink)
Rodney Farmer
I have a similar problem on my Pavillion dv9000 and I have also downloaded
the latest HP drivers.
A workaround solution for me is to open Control Panel/System and navigate to
Device Manager, select the webcam under imaging devices and right click then
select disable. After a few seconds right click again and select Enable,
the webcam then works, but this sequence needs to be performed almost every
time I use the built in webcam. A similar result can be obtained by putting
comp into sleep mode for a minute or so and then return to normal operation.
Hope this works for you.
Rod Farmer
news:98BD1D8B-77DD-46DD-8846-440C26B7006E@xxxxxx
> able
>> >webcam.
>> > I
>> > Any
>> > Thanks!
>> > "I
>> > this
>> > then
Old 02-12-2009   #5 (permalink)
Kevin
Like Erin, I also have a Pavilion dv2000. After installing Vista and all the
MS updates and installing all the lastest and greatest updates from HP's
website, my webcam still does not work. As a matter of fact, Vista does not
even think there is a webcam, it does not eshow up in Device Manager and like
Erin, I have an option to unistall the webcam, but nothing else.
For what ever reason, Vista is not loading the drivers for the built-in
webcam. Even if I choose legacy hardware or do a manual search.
Any other ideas??
"Rodney Farmer" wrote:
Quote:
> Hi,
> Rod Farmer
> > able
> >> >webcam.
> >> > I
> >> > Any
> >> > Thanks!
> >> > "I
> >> > this
> >> > then
Built in Webcam problems please help. Drivers
Built in webcam Vista General
Built-in webcam Vista General
built in webcam Vista hardware & devices
built-in webcam not working Vista hardware & devices
