| | memory problems? My 10 month old computer is showing 98% full on "C" drive (64.4 GB installed, 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused as to why it is almost full when I hardly have anything on it yet. I've cleaned it up the best I can and deleted all that I think I can and I've defragmented after-with little or no change. I'm 10 months new to this computer world but any advice? |
| | Re: memory problems? Try do the following: Go to... Quote: >All Programs Quote: >>Maintenance Quote: >>>Problem Reports and Solutions Let it do whatever it has and close. Then run Disk Cleanup... Go to... Quote: >All Programs Quote: >>Accessories Quote: >>>Disk Cleanup "LouLou" <LouLou@xxxxxx> wrote in message news:5D2BA554-5DD8-4495-ABC4-03C03D76F3A0@xxxxxx Quote: > My 10 month old computer is showing 98% full on "C" drive (64.4 GB > installed, > 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused > as > to why it is almost full when I hardly have anything on it yet. I've > cleaned > it up the best I can and deleted all that I think I can and I've > defragmented > after-with little or no change. I'm 10 months new to this computer world > but > any advice? |
| | Re: memory problems? Hi, After deleting, did you empty the recycle bin? Have you adjusted the amount of space used by System Restore? Do you store a lot of picture and video files? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "LouLou" <LouLou@xxxxxx> wrote in message news:5D2BA554-5DD8-4495-ABC4-03C03D76F3A0@xxxxxx Quote: > My 10 month old computer is showing 98% full on "C" drive (64.4 GB > installed, > 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused > as > to why it is almost full when I hardly have anything on it yet. I've > cleaned > it up the best I can and deleted all that I think I can and I've > defragmented > after-with little or no change. I'm 10 months new to this computer world > but > any advice? |
| | Re: memory problems? Also recognize that restore points and file indexing can take a lot of disk space. "LouLou" <LouLou@xxxxxx> wrote in message news:5D2BA554-5DD8-4495-ABC4-03C03D76F3A0@xxxxxx Quote: > My 10 month old computer is showing 98% full on "C" drive (64.4 GB > installed, > 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused > as > to why it is almost full when I hardly have anything on it yet. I've > cleaned > it up the best I can and deleted all that I think I can and I've > defragmented > after-with little or no change. I'm 10 months new to this computer world > but > any advice? |
| | Re: memory problems? Also, one point: This is not a memory problem, this is a hard drive space problem. "Memory" in the vernacular generally refers to the amount of physically installed ram plus the virtual memory (commonly known as the paging file). -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Rick Rogers" <rick@xxxxxx> wrote in message news:Oep84T%23VIHA.1184@xxxxxx Quote: > Hi, > > After deleting, did you empty the recycle bin? > Have you adjusted the amount of space used by System Restore? > Do you store a lot of picture and video files? > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "LouLou" <LouLou@xxxxxx> wrote in message > news:5D2BA554-5DD8-4495-ABC4-03C03D76F3A0@xxxxxx Quote: >> My 10 month old computer is showing 98% full on "C" drive (64.4 GB >> installed, >> 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very >> confused as >> to why it is almost full when I hardly have anything on it yet. I've >> cleaned >> it up the best I can and deleted all that I think I can and I've >> defragmented >> after-with little or no change. I'm 10 months new to this computer world >> but >> any advice? |
| | #6 (permalink) |
| | Re: memory problems? Hi, LouLou. Welcome to the wonderful world of computers! ;<) One of the threshold problems of computing is terminology, and one term that we all have to learn is "memory". That term generally refers to the memory chips plugged into the mainboard (also called the "motherboard"). We never see these chips unless we open the computer case, but they are involved in every operation the computer performs. But when the power goes off, they forget everything and have to be reminded when the computer is turned on again. So, before the computer shuts down, everything must be safely stored on the hard disk drive, which does not forget when turned off. When the computer is turned on, the Vista operating system is copied from the hard drive to the system memory again, and then the refreshed memory takes control and runs the computer. This usually takes less than a minute; that's what's happening between the time we hit the switch and when we see the Desktop and can start using Vista. We generally refer to space on the hard disk as "storage" or just as "disk space". Today's hard drives are usually at least 20 GB and many of them hold hundreds of GB each, with 300+ GB drives becoming quite common. "Memory" sizes are more typically 512 MB (.5 GB), 1 GB or 2 GB. Your question really is about hard drive space, rather than "memory", as most of us use the term, so "storage problems" might have been a more appropriate subject line. And, yes, many of us have problems with running out of disk space. Rick and the others have given you some good tips for recovering some of your disk space. RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2008 in Vista Ultimate x64) "LouLou" <LouLou@xxxxxx> wrote in message news:5D2BA554-5DD8-4495-ABC4-03C03D76F3A0@xxxxxx Quote: > My 10 month old computer is showing 98% full on "C" drive (64.4 GB > installed, > 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused > as > to why it is almost full when I hardly have anything on it yet. I've > cleaned > it up the best I can and deleted all that I think I can and I've > defragmented > after-with little or no change. I'm 10 months new to this computer world > but > any advice? |
| | #7 (permalink) |
| Vista 32bit Prem | Re: memory problems? Sounds like the it could have been formatted incorrectly at the factory. Back up all your stuff and reload the OS. Make sure you see all the available HD space on reload. Sees 64 then its most likely an 80gb drive. Weird to see that small of a HD they usally had 120gb drives or bigger 10 months ago. Why I think it may need a reformat size of HD doesnt make sence. My 10 month old computer is showing 98% full on "C" drive (64.4 GB installed, 1.41 GB left) I'm running Windows Vista Home Basic. I'm just very confused as to why it is almost full when I hardly have anything on it yet. I've cleaned it up the best I can and deleted all that I think I can and I've defragmented after-with little or no change. I'm 10 months new to this computer world but any advice? |
| Memory problems | Vista hardware & devices | |||
| Memory problems...? | General Discussion | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| memory problems with 4 gb ram | General Discussion | |||
| Memory Problems | Vista hardware & devices | |||
