Vista - Caps Lock / Bloc Num problem
Old 01-18-2008   #11 (permalink)
stewiggle
Re: Caps Lock / Bloc Num problem
Well done! The MS-DOS boot now works also on the laptop.. but the Caps Lock
problem still remains, also in the DOS configuration. So I think Vista can be
not guilty this time, I can lean towards the hardware problem and I'll stop
searching for software solutions..
Thank you very much both to Colin and Carlos!
"Colin Barnhorst" wrote:
Quote:
> The boot order may be set in the BIOS such that PXE is first, the hdd
> second, and the cd drive third. Change the order so that the cd drive is
> ahead of the hdd and then it should boot from the cd.
> "stewiggle" <stewiggle@xxxxxx> wrote in message
> news:71C8A9C4-ED06-45C8-BE8D-6119990DB79E@xxxxxx
Quote:
> > Yes. It would be a smart test.. but I have some problems. I did a MS-DOS
> > boot
> > disk with a PC with Windows XP (and it works on this PC), because the
> > laptop
> > with Vista hasn't the floppy drive. Then I tried on Vista, but the system
> > starts with Vista and completely ignore the CD boot.
> > I was looking for MS-DOS boot ISO image on internet, but I can't find
> > anything.
> > "Carlos" wrote:
Quote:
> >> And what about the last suggestion of a bootable floppy for testing the
> >> caps
> >> lock key?
> >> That would cut the problem in a half.
> >> If it still fails it is hardware, if it doesn't fail: it is Vista.
> >> Carlos
> >> "stewiggle" wrote:
> >> > >"Smells like a hardware failure to me."
> >> > It would be very strange.. the keyboard works fine if I don't press
> >> > buttons
> >> > lock.
> >> > >"Is your laptop still under warranty?"
> >> > Yes, it has 2 months, so I'm taking some time to investigate all the
> >> > software possibilities before surrendering to an hardware problem and
> >> > exploiting the warranty..
> >> > >"One last shot would be to restore your Windows Vista to a date when
> >> > >you didn't have this problem."
> >> > Already done for the touchpad problem, but it didn't solve anything.. I
> >> > could try also for the keyboard problem..
> >> > I think that the latest step could be the complete format of the
> >> > laptop.. if
> >> > some problem still exists, then I could be sure that is an hardware
> >> > problem..
> >> > The fact that searching for the web I can't find anyone with the same
> >> > problem is quite strange..
> >> > Thanks.
> >> > > The fact that you have a non-working touchpad together with the
> >> > > keyboard
> >> > > freezing is suspicious.
> >> > > you
> >> > > If the problem persists, then we would be sure it is hardware
> >> > > related.
> >> > > Or make a bootable DOS floppy and test the keyboard in a different
> >> > > environment.
> >> > > Carlos
> >> > > "stewiggle" wrote:
> >> > > > Ok, this is the situation. When the caps lock ON window appears in
> >> > > > the right
> >> > > > bottom corner of the screen (it's the same thing with the Num
> >> > > > Lock), the
> >> > > > laptop keyboard completely die. But connecting an external USB, I
> >> > > > checked
> >> > > > that everything is fine with the external keyboard.
> >> > > > To restore the functionality of the laptop keyboard I have to
> >> > > > restart the
> >> > > > system.
> >> > > > What could I do? The Caps Lock is not so hard to press, even
> >> > > > without
> >> > > > intention..
> >> > > > > I understood it was a laptop from your mention of a touchpad.
> >> > > > > message
> >> > > > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx
> >> > > > > > Oh, sorry.. I didn't specify that I'm talking about a notebook.
> >> > > > > > I'll try to verify if an external keyboard works.. however this
> >> > > > > > will not
> >> > > > > > solve my problem..
> >> > > > > >> Do you have a usb keyboard you can try?
> >> > > > > >> message
> >> > > > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx
> >> > > > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the
> >> > > > > >> > keyboard gets
> >> > > > > >> > disabled, and it doesn't work anymore.. I have to restart
> >> > > > > >> > the system.
> >> > > > > >> > I installed the last windows vista update few days ago, and
> >> > > > > >> > also my
> >> > > > > >> > touchpad
> >> > > > > >> > now doesn't work (it's not a problem of drivers update), I
> >> > > > > >> > don't know
> >> > > > > >> > if
> >> > > > > >> > this
> >> > > > > >> > one can be the reason of the keyboard problem.
> >> > > > > >> > Anyone has the same problems? Any suggestions?
> >> > > > > >> > Thanks.
Old 01-18-2008   #12 (permalink)
Colin Barnhorst
You're welcome.
news:FFD41215-9C47-495C-AC70-D12476483BFE@xxxxxx
> Lock
> be
> stop
>> > MS-DOS
>> > boot
>> > laptop
>> > system
>> > anything.
>> >> the
>> >> caps
>> >> lock key?
>> >> Carlos
>> >> > buttons
>> >> > lock.
>> >> > and
>> >> > >when
>> >> > anything.. I
>> >> > laptop.. if
>> >> > problem..
>> >> > same
>> >> > Thanks.
>> >> > > keyboard
>> >> > > when
>> >> > > you
>> >> > > related.
>> >> > > environment.
>> >> > > Carlos
>> >> > > > in
>> >> > > > the right
>> >> > > > Lock), the
>> >> > > > I
>> >> > > > checked
>> >> > > > restart the
>> >> > > > system.
>> >> > > > without
>> >> > > > intention..
>> >> > > > > message
>> >> > > > > > notebook.
>> >> > > > > > this
>> >> > > > > > will not
>> >> > > > > > solve my problem..
>> >> > > > > >> message
>> >> > > > > >> > keyboard gets
>> >> > > > > >> > the system.
>> >> > > > > >> > and
>> >> > > > > >> > also my
>> >> > > > > >> > touchpad
>> >> > > > > >> > I
>> >> > > > > >> > don't know
>> >> > > > > >> > if
>> >> > > > > >> > this
>> >> > > > > >> > Thanks.
Old 01-18-2008   #13 (permalink)
Carlos
You are quite welcome.
For boot disks/CDs images try here:
http://www.bootdisk.com/
Carlos
> > > boot
> > > laptop
> > > anything.
> > >> caps
> > >> lock key?
> > >> Carlos
> > >> > buttons
> > >> > lock.
> > >> > laptop.. if
> > >> > problem..
> > >> > Thanks.
> > >> > > keyboard
> > >> > > you
> > >> > > related.
> > >> > > environment.
> > >> > > Carlos
> > >> > > > the right
> > >> > > > Lock), the
> > >> > > > checked
> > >> > > > restart the
> > >> > > > system.
> > >> > > > without
> > >> > > > intention..
> > >> > > > > message
> > >> > > > > > will not
> > >> > > > > > solve my problem..
> > >> > > > > >> message
> > >> > > > > >> > keyboard gets
> > >> > > > > >> > the system.
> > >> > > > > >> > also my
> > >> > > > > >> > touchpad
> > >> > > > > >> > don't know
> > >> > > > > >> > if
> > >> > > > > >> > this
> > >> > > > > >> > Thanks.
Notification area/ How to get rid of Caps Lock, Scroll Lock Vista General
Caps Lock Off Vista General
CAPS lock / SHIFT lock difficulty Vista General
caps/num lock Vista installation & setup
Caps Lock problem Vista hardware & devices
