| Guest | Caps Lock / Bloc Num problem Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets disabled, and it doesn't work anymore.. I have to restart the system. I installed the last windows vista update few days ago, and also my touchpad now doesn't work (it's not a problem of drivers update), I don't know if this one can be the reason of the keyboard problem. Anyone has the same problems? Any suggestions? Thanks. |
| Guest | Re: Caps Lock / Bloc Num problem Do you have a usb keyboard you can try? "stewiggle" <stewiggle@xxxxxx> wrote in message news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx Quote: > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > disabled, and it doesn't work anymore.. I have to restart the system. > > I installed the last windows vista update few days ago, and also my > touchpad > now doesn't work (it's not a problem of drivers update), I don't know if > this > one can be the reason of the keyboard problem. > > Anyone has the same problems? Any suggestions? > > Thanks. |
| Guest | Re: Caps Lock / Bloc Num problem Oh, sorry.. I didn't specify that I'm talking about a notebook. I'll try to verify if an external keyboard works.. however this will not solve my problem.. :'( "Colin Barnhorst" wrote: Quote: > Do you have a usb keyboard you can try? > > "stewiggle" <stewiggle@xxxxxx> wrote in message > news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx Quote: > > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > > disabled, and it doesn't work anymore.. I have to restart the system. > > > > I installed the last windows vista update few days ago, and also my > > touchpad > > now doesn't work (it's not a problem of drivers update), I don't know if > > this > > one can be the reason of the keyboard problem. > > > > Anyone has the same problems? Any suggestions? > > > > Thanks. |
| Guest | Re: Caps Lock / Bloc Num problem I understood it was a laptop from your mention of a touchpad. "stewiggle" <stewiggle@xxxxxx> wrote in message news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx Quote: > Oh, sorry.. I didn't specify that I'm talking about a notebook. > I'll try to verify if an external keyboard works.. however this will not > solve my problem.. > :'( > > "Colin Barnhorst" wrote: > Quote: >> Do you have a usb keyboard you can try? >> >> "stewiggle" <stewiggle@xxxxxx> wrote in message >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx Quote: >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets >> > disabled, and it doesn't work anymore.. I have to restart the system. >> > >> > I installed the last windows vista update few days ago, and also my >> > touchpad >> > now doesn't work (it's not a problem of drivers update), I don't know >> > if >> > this >> > one can be the reason of the keyboard problem. >> > >> > Anyone has the same problems? Any suggestions? >> > >> > Thanks. |
| Guest | Re: Caps Lock / Bloc Num problem Ok, this is the situation. When the caps lock ON window appears in the right bottom corner of the screen (it's the same thing with the Num Lock), the laptop keyboard completely die. But connecting an external USB, I checked that everything is fine with the external keyboard. To restore the functionality of the laptop keyboard I have to restart the system. What could I do? The Caps Lock is not so hard to press, even without intention.. "Colin Barnhorst" wrote: Quote: > I understood it was a laptop from your mention of a touchpad. > > "stewiggle" <stewiggle@xxxxxx> wrote in message > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx Quote: > > Oh, sorry.. I didn't specify that I'm talking about a notebook. > > I'll try to verify if an external keyboard works.. however this will not > > solve my problem.. > > :'( > > > > "Colin Barnhorst" wrote: > > Quote: > >> Do you have a usb keyboard you can try? > >> > >> "stewiggle" <stewiggle@xxxxxx> wrote in message > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx > >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > >> > disabled, and it doesn't work anymore.. I have to restart the system. > >> > > >> > I installed the last windows vista update few days ago, and also my > >> > touchpad > >> > now doesn't work (it's not a problem of drivers update), I don't know > >> > if > >> > this > >> > one can be the reason of the keyboard problem. > >> > > >> > Anyone has the same problems? Any suggestions? > >> > > >> > Thanks. > >> |
| | #6 (permalink) |
| Guest | Re: Caps Lock / Bloc Num problem Smells like a hardware failure to me. The fact that you have a non-working touchpad together with the keyboard freezing is suspicious. Is your laptop still under warranty? One last shot would be to restore your Windows Vista to a date when you didn't have this problem. If the problem persists, then we would be sure it is hardware related. Or make a bootable DOS floppy and test the keyboard in a different environment. Carlos "stewiggle" wrote: Quote: > Ok, this is the situation. When the caps lock ON window appears in the right > bottom corner of the screen (it's the same thing with the Num Lock), the > laptop keyboard completely die. But connecting an external USB, I checked > that everything is fine with the external keyboard. > To restore the functionality of the laptop keyboard I have to restart the > system. > > What could I do? The Caps Lock is not so hard to press, even without > intention.. > > > "Colin Barnhorst" wrote: > Quote: > > I understood it was a laptop from your mention of a touchpad. > > > > "stewiggle" <stewiggle@xxxxxx> wrote in message > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx Quote: > > > Oh, sorry.. I didn't specify that I'm talking about a notebook. > > > I'll try to verify if an external keyboard works.. however this will not > > > solve my problem.. > > > :'( > > > > > > "Colin Barnhorst" wrote: > > > > > >> Do you have a usb keyboard you can try? > > >> > > >> "stewiggle" <stewiggle@xxxxxx> wrote in message > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > > >> > disabled, and it doesn't work anymore.. I have to restart the system. > > >> > > > >> > I installed the last windows vista update few days ago, and also my > > >> > touchpad > > >> > now doesn't work (it's not a problem of drivers update), I don't know > > >> > if > > >> > this > > >> > one can be the reason of the keyboard problem. > > >> > > > >> > Anyone has the same problems? Any suggestions? > > >> > > > >> > Thanks. > > >> |
| | #7 (permalink) |
| Guest | Re: Caps Lock / Bloc Num problem >"Smells like a hardware failure to me." It would be very strange.. the keyboard works fine if I don't press buttons lock. Quote: >"Is your laptop still under warranty?" software possibilities before surrendering to an hardware problem and exploiting the warranty.. Quote: >"One last shot would be to restore your Windows Vista to a date when you didn't have this problem." could try also for the keyboard problem.. I think that the latest step could be the complete format of the laptop.. if some problem still exists, then I could be sure that is an hardware problem.. The fact that searching for the web I can't find anyone with the same problem is quite strange.. Thanks. "Carlos" wrote: Quote: > Smells like a hardware failure to me. > The fact that you have a non-working touchpad together with the keyboard > freezing is suspicious. > Is your laptop still under warranty? > One last shot would be to restore your Windows Vista to a date when you > didn't have this problem. > If the problem persists, then we would be sure it is hardware related. > Or make a bootable DOS floppy and test the keyboard in a different > environment. > Carlos > > "stewiggle" wrote: > Quote: > > Ok, this is the situation. When the caps lock ON window appears in the right > > bottom corner of the screen (it's the same thing with the Num Lock), the > > laptop keyboard completely die. But connecting an external USB, I checked > > that everything is fine with the external keyboard. > > To restore the functionality of the laptop keyboard I have to restart the > > system. > > > > What could I do? The Caps Lock is not so hard to press, even without > > intention.. > > > > > > "Colin Barnhorst" wrote: > > Quote: > > > I understood it was a laptop from your mention of a touchpad. > > > > > > "stewiggle" <stewiggle@xxxxxx> wrote in message > > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx > > > > Oh, sorry.. I didn't specify that I'm talking about a notebook. > > > > I'll try to verify if an external keyboard works.. however this will not > > > > solve my problem.. > > > > :'( > > > > > > > > "Colin Barnhorst" wrote: > > > > > > > >> Do you have a usb keyboard you can try? > > > >> > > > >> "stewiggle" <stewiggle@xxxxxx> wrote in message > > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx > > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > > > >> > disabled, and it doesn't work anymore.. I have to restart the system. > > > >> > > > > >> > I installed the last windows vista update few days ago, and also my > > > >> > touchpad > > > >> > now doesn't work (it's not a problem of drivers update), I don't know > > > >> > if > > > >> > this > > > >> > one can be the reason of the keyboard problem. > > > >> > > > > >> > Anyone has the same problems? Any suggestions? > > > >> > > > > >> > Thanks. > > > >> > > > |
| | #8 (permalink) |
| Guest | Re: Caps Lock / Bloc Num problem And what about the last suggestion of a bootable floppy for testing the caps lock key? That would cut the problem in a half. If it still fails it is hardware, if it doesn't fail: it is Vista. Carlos "stewiggle" wrote: Quote: Quote: > >"Smells like a hardware failure to me." > lock. > Quote: > >"Is your laptop still under warranty?" > software possibilities before surrendering to an hardware problem and > exploiting the warranty.. > Quote: > >"One last shot would be to restore your Windows Vista to a date when you didn't have this problem." > could try also for the keyboard problem.. > > I think that the latest step could be the complete format of the laptop.. if > some problem still exists, then I could be sure that is an hardware problem.. > The fact that searching for the web I can't find anyone with the same > problem is quite strange.. > Thanks. > > > "Carlos" wrote: > Quote: > > Smells like a hardware failure to me. > > The fact that you have a non-working touchpad together with the keyboard > > freezing is suspicious. > > Is your laptop still under warranty? > > One last shot would be to restore your Windows Vista to a date when you > > didn't have this problem. > > If the problem persists, then we would be sure it is hardware related. > > Or make a bootable DOS floppy and test the keyboard in a different > > environment. > > Carlos > > > > "stewiggle" wrote: > > Quote: > > > Ok, this is the situation. When the caps lock ON window appears in the right > > > bottom corner of the screen (it's the same thing with the Num Lock), the > > > laptop keyboard completely die. But connecting an external USB, I checked > > > that everything is fine with the external keyboard. > > > To restore the functionality of the laptop keyboard I have to restart the > > > system. > > > > > > What could I do? The Caps Lock is not so hard to press, even without > > > intention.. > > > > > > > > > "Colin Barnhorst" wrote: > > > > > > > I understood it was a laptop from your mention of a touchpad. > > > > > > > > "stewiggle" <stewiggle@xxxxxx> wrote in message > > > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx > > > > > Oh, sorry.. I didn't specify that I'm talking about a notebook. > > > > > I'll try to verify if an external keyboard works.. however this will not > > > > > solve my problem.. > > > > > :'( > > > > > > > > > > "Colin Barnhorst" wrote: > > > > > > > > > >> Do you have a usb keyboard you can try? > > > > >> > > > > >> "stewiggle" <stewiggle@xxxxxx> wrote in message > > > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx > > > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > > > > >> > disabled, and it doesn't work anymore.. I have to restart the system. > > > > >> > > > > > >> > I installed the last windows vista update few days ago, and also my > > > > >> > touchpad > > > > >> > now doesn't work (it's not a problem of drivers update), I don't know > > > > >> > if > > > > >> > this > > > > >> > one can be the reason of the keyboard problem. > > > > >> > > > > > >> > Anyone has the same problems? Any suggestions? > > > > >> > > > > > >> > Thanks. > > > > >> > > > > |
| | #9 (permalink) |
| Guest | Re: Caps Lock / Bloc Num problem Yes. It would be a smart test.. but I have some problems. I did a MS-DOS boot disk with a PC with Windows XP (and it works on this PC), because the laptop with Vista hasn't the floppy drive. Then I tried on Vista, but the system starts with Vista and completely ignore the CD boot. I was looking for MS-DOS boot ISO image on internet, but I can't find anything. "Carlos" wrote: Quote: > And what about the last suggestion of a bootable floppy for testing the caps > lock key? > That would cut the problem in a half. > If it still fails it is hardware, if it doesn't fail: it is Vista. > Carlos > > "stewiggle" wrote: > Quote: Quote: > > >"Smells like a hardware failure to me." > > lock. > > Quote: > > >"Is your laptop still under warranty?" > > software possibilities before surrendering to an hardware problem and > > exploiting the warranty.. > > Quote: > > >"One last shot would be to restore your Windows Vista to a date when you didn't have this problem." > > could try also for the keyboard problem.. > > > > I think that the latest step could be the complete format of the laptop.. if > > some problem still exists, then I could be sure that is an hardware problem.. > > The fact that searching for the web I can't find anyone with the same > > problem is quite strange.. > > Thanks. > > > > > > "Carlos" wrote: > > Quote: > > > Smells like a hardware failure to me. > > > The fact that you have a non-working touchpad together with the keyboard > > > freezing is suspicious. > > > Is your laptop still under warranty? > > > One last shot would be to restore your Windows Vista to a date when you > > > didn't have this problem. > > > If the problem persists, then we would be sure it is hardware related. > > > Or make a bootable DOS floppy and test the keyboard in a different > > > environment. > > > Carlos > > > > > > "stewiggle" wrote: > > > > > > > Ok, this is the situation. When the caps lock ON window appears in the right > > > > bottom corner of the screen (it's the same thing with the Num Lock), the > > > > laptop keyboard completely die. But connecting an external USB, I checked > > > > that everything is fine with the external keyboard. > > > > To restore the functionality of the laptop keyboard I have to restart the > > > > system. > > > > > > > > What could I do? The Caps Lock is not so hard to press, even without > > > > intention.. > > > > > > > > > > > > "Colin Barnhorst" wrote: > > > > > > > > > I understood it was a laptop from your mention of a touchpad. > > > > > > > > > > "stewiggle" <stewiggle@xxxxxx> wrote in message > > > > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx > > > > > > Oh, sorry.. I didn't specify that I'm talking about a notebook. > > > > > > I'll try to verify if an external keyboard works.. however this will not > > > > > > solve my problem.. > > > > > > :'( > > > > > > > > > > > > "Colin Barnhorst" wrote: > > > > > > > > > > > >> Do you have a usb keyboard you can try? > > > > > >> > > > > > >> "stewiggle" <stewiggle@xxxxxx> wrote in message > > > > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx > > > > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the keyboard gets > > > > > >> > disabled, and it doesn't work anymore.. I have to restart the system. > > > > > >> > > > > > > >> > I installed the last windows vista update few days ago, and also my > > > > > >> > touchpad > > > > > >> > now doesn't work (it's not a problem of drivers update), I don't know > > > > > >> > if > > > > > >> > this > > > > > >> > one can be the reason of the keyboard problem. > > > > > >> > > > > > > >> > Anyone has the same problems? Any suggestions? > > > > > >> > > > > > > >> > Thanks. > > > > > >> > > > > > |
| | #10 (permalink) |
| Guest | Re: Caps Lock / Bloc Num problem The boot order may be set in the BIOS such that PXE is first, the hdd second, and the cd drive third. Change the order so that the cd drive is ahead of the hdd and then it should boot from the cd. "stewiggle" <stewiggle@xxxxxx> wrote in message news:71C8A9C4-ED06-45C8-BE8D-6119990DB79E@xxxxxx Quote: > Yes. It would be a smart test.. but I have some problems. I did a MS-DOS > boot > disk with a PC with Windows XP (and it works on this PC), because the > laptop > with Vista hasn't the floppy drive. Then I tried on Vista, but the system > starts with Vista and completely ignore the CD boot. > I was looking for MS-DOS boot ISO image on internet, but I can't find > anything. > > > "Carlos" wrote: > Quote: >> And what about the last suggestion of a bootable floppy for testing the >> caps >> lock key? >> That would cut the problem in a half. >> If it still fails it is hardware, if it doesn't fail: it is Vista. >> Carlos >> >> "stewiggle" wrote: >> Quote: >> > >"Smells like a hardware failure to me." >> > It would be very strange.. the keyboard works fine if I don't press >> > buttons >> > lock. >> > >> > >"Is your laptop still under warranty?" >> > Yes, it has 2 months, so I'm taking some time to investigate all the >> > software possibilities before surrendering to an hardware problem and >> > exploiting the warranty.. >> > >> > >"One last shot would be to restore your Windows Vista to a date when >> > >you didn't have this problem." >> > Already done for the touchpad problem, but it didn't solve anything.. I >> > could try also for the keyboard problem.. >> > >> > I think that the latest step could be the complete format of the >> > laptop.. if >> > some problem still exists, then I could be sure that is an hardware >> > problem.. >> > The fact that searching for the web I can't find anyone with the same >> > problem is quite strange.. >> > Thanks. >> > >> > >> > "Carlos" wrote: >> > >> > > Smells like a hardware failure to me. >> > > The fact that you have a non-working touchpad together with the >> > > keyboard >> > > freezing is suspicious. >> > > Is your laptop still under warranty? >> > > One last shot would be to restore your Windows Vista to a date when >> > > you >> > > didn't have this problem. >> > > If the problem persists, then we would be sure it is hardware >> > > related. >> > > Or make a bootable DOS floppy and test the keyboard in a different >> > > environment. >> > > Carlos >> > > >> > > "stewiggle" wrote: >> > > >> > > > Ok, this is the situation. When the caps lock ON window appears in >> > > > the right >> > > > bottom corner of the screen (it's the same thing with the Num >> > > > Lock), the >> > > > laptop keyboard completely die. But connecting an external USB, I >> > > > checked >> > > > that everything is fine with the external keyboard. >> > > > To restore the functionality of the laptop keyboard I have to >> > > > restart the >> > > > system. >> > > > >> > > > What could I do? The Caps Lock is not so hard to press, even >> > > > without >> > > > intention.. >> > > > >> > > > >> > > > "Colin Barnhorst" wrote: >> > > > >> > > > > I understood it was a laptop from your mention of a touchpad. >> > > > > >> > > > > "stewiggle" <stewiggle@xxxxxx> wrote in >> > > > > message >> > > > > news:FCA8079E-B72C-43E6-85EE-6FD020EFB233@xxxxxx >> > > > > > Oh, sorry.. I didn't specify that I'm talking about a notebook. >> > > > > > I'll try to verify if an external keyboard works.. however this >> > > > > > will not >> > > > > > solve my problem.. >> > > > > > :'( >> > > > > > >> > > > > > "Colin Barnhorst" wrote: >> > > > > > >> > > > > >> Do you have a usb keyboard you can try? >> > > > > >> >> > > > > >> "stewiggle" <stewiggle@xxxxxx> wrote in >> > > > > >> message >> > > > > >> news:423CA95B-5063-496F-A7AF-AA9C069C414B@xxxxxx >> > > > > >> > Whenever I press the Caps Lock or Bloc Num buttons, the >> > > > > >> > keyboard gets >> > > > > >> > disabled, and it doesn't work anymore.. I have to restart >> > > > > >> > the system. >> > > > > >> > >> > > > > >> > I installed the last windows vista update few days ago, and >> > > > > >> > also my >> > > > > >> > touchpad >> > > > > >> > now doesn't work (it's not a problem of drivers update), I >> > > > > >> > don't know >> > > > > >> > if >> > > > > >> > this >> > > > > >> > one can be the reason of the keyboard problem. >> > > > > >> > >> > > > > >> > Anyone has the same problems? Any suggestions? >> > > > > >> > >> > > > > >> > Thanks. >> > > > > >> >> > > > > |
| Notification area/ How to get rid of Caps Lock, Scroll Lock | Vista General | |||
| Caps Lock Off | Vista General | |||
| CAPS lock / SHIFT lock difficulty | Vista General | |||
| caps/num lock | Vista installation & setup | |||
| Caps Lock problem | Vista hardware & devices | |||
