Vista - External Monitor Disables Screen Saver and Power Plan
Old 01-17-2008   #1 (permalink)
bigvee_nh
I have replaced an HP Pavilion notebook running XP Pro with a new HP Pavilion
notebook running Vista Ultimate. I had been using an external Acer LCD
monitor with the old notebook. With the new notebook and Vista, the external
monitor seems to disable both the screen saver and the power plan settings.
The display simply stays on indefinitely. On a couple of rare occasions I was
able to get it working correctly, but it does not last. I would like the
external dispaly to sleep at the appropriate times as set in the power plan.
This problem did not exist with the XP Pro notebook.
bigvee_nh
Old 02-05-2008   #2 (permalink)
TNJules
Re: External Monitor Disables Screen Saver and Power Plan
On Jan 17, 4:08 pm, bigvee_nh <bigve...@xxxxxx>
> bigvee_nh
I am having the same problem. Did you find a solution?
TNJules
EXTERNAL MONITOR KILLS POWER PLAN ON HP NOTEBOOK Vista General
Monitor in Power Saver mode Vista hardware & devices
ehtray disables screen saver Vista General
Vista Remote Desktop disables monitor power saving. Vista General
Screen Saver and Power Plan Vista installation & setup
