Vista - Wireless Laser Desktop problem
Old 01-19-2008   #1 (permalink)
Drew
I, for the life of me, can't get my Comfort Keyboard V 1.0 to register in
Vista. There's no keyboard even showing up in the hardware tab. I've gotten
the updated files from MS, but no luck. It works in the BIOS though. Any help
is appreciated.
Old 01-19-2008   #2 (permalink)
Quaoar
Re: Wireless Laser Desktop problem
> is appreciated.
Do this: remove the transmitter from the computer. Wait a few seconds,
then replug the transmitter, and wait for some indication that the
Vista's daemon has awoken from its trance.
If the daemon say something about installing drivers, OK. If it says
your device has failed, unplug the transmitter, wait for fifteen
seconds, then replug. Do this until you give up or the daemon has
finally awoken and installed the drivers.
Q
Old 01-20-2008   #3 (permalink)
Drew
Wow, I figured it out. I just plugged in the USB part of it only, and
unplugged the keyboard from the PS/2 adapter, and it worked. Thanks for the
suggestion though!
> Q
USB Keyboard installation problems (MS Wireless Laser Desktop 6000) Vista hardware & devices
Wireless Laser Desktop 6000 .NET General
Sporadic Wireless Laser Desktop 6000 Problems Vista hardware & devices
Microsoft wireless laser desktop 3000 Vista hardware & devices
MS wireless laser desktop 6000v2 Vista hardware & devices
