Vista - Re: Fujitsu Siemens Amilo Pro V2060 sound drivers
Old 01-21-2008   #1 (permalink)
shaji22
On Dec 25 2007, 11:10*pm, Justas <Jus...@xxxxxx>
wrote:
Quote:
> Hello. I have a bit old Amilo Pro V2060 and Windows Vista Bussiness. This
> notebook is not Vista capable, bus all in all Im using Vista on it. I have
> one major sound problem. It is somehow realted with sound drivers. Is there
> any way that I can use sound on this computer? Maybe some upgrades will help
> here... or so. Thank you.
hello, i also have the same problem. pls mail me to shaji22@xxxxxx,
if you found a solution.
thank you
shaji
Re: Fujitsu Siemens Laptop. Vista hardware & devices
TV-out on fujitsu-siemens Scaleo E not working Vista hardware & devices
impossible to use the microphone on a AMILO siemens Vista hardware & devices
Fujitsu Siemens Amilo 3438G Vista installation & setup
