Monitor Calibration Issues
  1. #1
    thunnus Guest
    I am trying to calibrate my home laptop LCD monitor using an X-Rite Eye One
    Display 2 unit for digital photography purposes. After calibration, the
    X-Rite unit creates a custom monitor profile and sets it as default. But the
    laptop reverts to the original monitor settings once the computer is
    rebooted. I can't get the corrected monitor profile to display even though
    the display settings show that profile as the default. I've tried "adding"
    the profile in advanced display settings and re-setting as the default but
    that has no effect. Only a new calibration will change the monitor to the
    desired settings and that only lasts until the next power down. During the
    boot process, I can see the monitor colors change three times
    (original>calibrated>back to original).
    My laptop is an HP Pavillion DV2000 using Vista Home Premium and with Intel
    GMA X3100 display adapter. BTW, my XP desktop was calibrated successfully
    without problems.
  2. #2
    BeckyWC Guest
    RE: Monitor Calibration Issues
    I am also having this problem. I have calibrated my monitor, and even
    though it is set as default vista will not use it, Vista loads it and then
    changes it once its loaded. Does anyone know of a solution?
    Thanks
    > without problems.
  3. #3
    thunnus Guest
    Becky,
    I was experiencing two problems. (1) Vista overriding the calibrated
    monitor profile during bootup and (2) Vista reverting back to the old profile
    after the screensaver kicks in or the monitor goes in sleep or hibernation
    mode.
    I have found a work around for the first problem. I installed a program
    called Startup Delayer which allows you to put a time delay on your startup
    programs. I put a delay of 60 seconds on the Calibration Loader and this
    allows the calibrated profile to survive past the boot process. This lasts
    until Vista kicks out of active mode for whatever reason (screensaver, sleep,
    hibernation, etc.). Once that happens, I have to reboot in order to have a
    calibrated screen. I cannot manually load the calibrated profile outside of
    the boot process.
    I know it is not a total solution but I hope it helps you somehow.
    > Thanks
    > > without problems.
  4. #4
    Newbie
    Vista Home Premium 32bit
    Local Time: 05:51 AM
    Re: Monitor Calibration Issues
    Hello...
    I had problems with my hardware calibreted display in what concerns to automatic ICC profile loading by windows Vista32 too.
    I solved this by using the displayprofile.exe free software from X-Rite because it can force the ICC profile data to be charged in the memory of video card.
    DisplayProfile Freeware for Windows NA
    The profile doesn't charge automaticaly through displayprofile.exe because it is a manual process but, at least, every time windows vista resets ICC profile after its boot or by any other action you described above you can call displayprofile.exe by clicking only its icon and select the desired profile name.
    You will not need to recalibrate the monitor every time windows vista ( and all others) shows all its enormous problems list.
    Miguel Garcia
  5. #5
    Newbie
    I don't know if web addresses can be posted here but in case they are not you can search in google for "x-rite" and in x-rite search for "displayprofile" ( not "displayprofile.exe).
  6. #6
    Newbie
    Vista Ultimate x64
    Local Time: 12:51 AM
    Thanks for the suggestion for the profile loader. It works great and easily allows me to compare various profiles easily.
    Dan Kosmayer
  7. #7
    Newbie
    Vista Ultimate x64
    The Display Profile Loader works great on my Vista 64. I highly recommend it.
    X-Rite: Get exactly the color you need, every time, anywhere in the world.
    Dan Kosmayer
    Dan Kosmayer Fine Art Photography
Monitor Calibration Issues problems?
Monitor Calibration Submarine Chillout Room 6 05 Sep 2009
Vista 64-bit and monitor calibration paulajane Vista hardware & devices 3 10 Jan 2009
Monitor Calibration thunnus Vista music pictures video 0 22 Jan 2008
Monitor Calibration thunnus Vista hardware & devices 0 22 Jan 2008
Monitor Calibration Paul_C General Discussion 0 22 Oct 2007
