| Guest | Problems with PCMCIA network card and the dreaded Code 10 error All, I have a home built Vista Ultimate machine which I am attempting to setup in a "remote" location in my house with wireless. The plan is to utilize a Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to PCI card installed in my machine. I have already tested the WPC4400N in my laptop and it works fine. The Rosewill PCMCIA to PCI card also appears to install without any issues. (I do not have any other PCMCIA cards available to test...) However, when windows detects the device and installs drivers (either using Windows update or a manually) it does not work. There is a Code 10 error on the Properties page in the Device manager. Problem Report details are as follow: Product Wireless-N Business Notebook Adapter Problem Could not load driver software Date 1/22/2008 1:00 PM Status Report Sent Description Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10. Problem signature Problem Event Name: PnPDeviceProblemCode Architecture: x86 Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} PnP problem code: 0000000A Driver name: NETMW145.sys Driver version: 2.1.4.3 Driver date: 01-08-2008 OS Version: 6.0.6000.2.0.0.256.1 Locale ID: 1033 Files that help describe the problem (some files may no longer be available) DMIBB92.tmp.log.xml LOGBBE1.tmp oem12.inf Extra information about the problem Bucket ID: 157734319 I'm fairly tech savvy, but once again generic/cross device error codes with little detail have left me stuck. I have mucked around with PCI settings in my BIOS to no avail. Any thoughts or suggestions? Thanks in advance for your assistance. |
| Guest | RE: Problems with PCMCIA network card and the dreaded Code 10 error Solved my own problem. Deleted the infcache.1 file in \Windows\Inf Maybe MS should auto check this file for corruption.....d "Xenor" wrote: Quote: > All, > I have a home built Vista Ultimate machine which I am attempting to setup > in a "remote" location in my house with wireless. The plan is to utilize a > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to PCI card > installed in my machine. I have already tested the WPC4400N in my laptop and > it works fine. The Rosewill PCMCIA to PCI card also appears to install > without any issues. (I do not have any other PCMCIA cards available to > test...) However, when windows detects the device and installs drivers > (either using Windows update or a manually) it does not work. There is a > Code 10 error on the Properties page in the Device manager. Problem Report > details are as follow: > > Product > Wireless-N Business Notebook Adapter > > Problem > Could not load driver software > > Date > 1/22/2008 1:00 PM > > Status > Report Sent > > Description > Windows was able to successfully install device driver software, but the > driver software encountered a problem when it tried to run. The problem code > is 10. > > Problem signature > Problem Event Name: PnPDeviceProblemCode > Architecture: x86 > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} > PnP problem code: 0000000A > Driver name: NETMW145.sys > Driver version: 2.1.4.3 > Driver date: 01-08-2008 > OS Version: 6.0.6000.2.0.0.256.1 > Locale ID: 1033 > > Files that help describe the problem (some files may no longer be available) > DMIBB92.tmp.log.xml > LOGBBE1.tmp > oem12.inf > > Extra information about the problem > Bucket ID: 157734319 > > I'm fairly tech savvy, but once again generic/cross device error codes with > little detail have left me stuck. I have mucked around with PCI settings in > my BIOS to no avail. Any thoughts or suggestions? Thanks in advance for > your assistance. |
| Guest | RE: Problems with PCMCIA network card and the dreaded Code 10 erro Hello, I'm glad you were able to resolve your issue. Did the infcache.1 file get recreated after it was deleted? If not, if you you may want to consider reading the following article which addresses corruption and deletion of the infcache.1 file. The file will be needed for future installation of other devices. http://support.microsoft.com/?kbid=937187 John I work at Microsoft. These are my opinions and not my employers. This posting is provided "AS IS" with no warranties, and confers no rights. -- -- Speaking for myself only. This posting is provided "AS IS" with no warranties, and confers no rights. -- "Xenor" wrote: Quote: > Solved my own problem. Deleted the infcache.1 file in \Windows\Inf > > Maybe MS should auto check this file for corruption.....d > > "Xenor" wrote: > Quote: > > All, > > I have a home built Vista Ultimate machine which I am attempting to setup > > in a "remote" location in my house with wireless. The plan is to utilize a > > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to PCI card > > installed in my machine. I have already tested the WPC4400N in my laptop and > > it works fine. The Rosewill PCMCIA to PCI card also appears to install > > without any issues. (I do not have any other PCMCIA cards available to > > test...) However, when windows detects the device and installs drivers > > (either using Windows update or a manually) it does not work. There is a > > Code 10 error on the Properties page in the Device manager. Problem Report > > details are as follow: > > > > Product > > Wireless-N Business Notebook Adapter > > > > Problem > > Could not load driver software > > > > Date > > 1/22/2008 1:00 PM > > > > Status > > Report Sent > > > > Description > > Windows was able to successfully install device driver software, but the > > driver software encountered a problem when it tried to run. The problem code > > is 10. > > > > Problem signature > > Problem Event Name: PnPDeviceProblemCode > > Architecture: x86 > > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 > > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} > > PnP problem code: 0000000A > > Driver name: NETMW145.sys > > Driver version: 2.1.4.3 > > Driver date: 01-08-2008 > > OS Version: 6.0.6000.2.0.0.256.1 > > Locale ID: 1033 > > > > Files that help describe the problem (some files may no longer be available) > > DMIBB92.tmp.log.xml > > LOGBBE1.tmp > > oem12.inf > > > > Extra information about the problem > > Bucket ID: 157734319 > > > > I'm fairly tech savvy, but once again generic/cross device error codes with > > little detail have left me stuck. I have mucked around with PCI settings in > > my BIOS to no avail. Any thoughts or suggestions? Thanks in advance for > > your assistance. |
| Guest | RE: Problems with PCMCIA network card and the dreaded Code 10 erro John, I have faced this problem again in a new machine build. Ultimately, I think that the folks doing the install of network drivers aren't cleaning up after themselves. I've found that by manually removing some of the profiles in the registry helps to clear the path for a clean install. It even requires removing a service that is created by thy wireless networking driver. I'm not sure who is to "blame" for it, but after searching various forums, it seems like many users of various Draft-N network adapters have problems. The common thread seems to be the Marvell TOPDOG chipset which various vendors use. Not sure if this is your area, but I'd like to pass on what I've learned to someone at Microsoft who could be working on a fix for this.. "JohnBuk [MSFT]" wrote: Quote: > Hello, > > I'm glad you were able to resolve your issue. Did the infcache.1 file get > recreated after it was deleted? If not, if you you may want to consider > reading the following article which addresses corruption and deletion of the > infcache.1 file. The file will be needed for future installation of other > devices. > > http://support.microsoft.com/?kbid=937187 > > John > > I work at Microsoft. These are my opinions and not my employers. > This posting is provided "AS IS" with no warranties, and confers no rights. > > -- > -- > Speaking for myself only. > This posting is provided "AS IS" with no warranties, and confers no rights. > -- > > > "Xenor" wrote: > Quote: > > Solved my own problem. Deleted the infcache.1 file in \Windows\Inf > > > > Maybe MS should auto check this file for corruption.....d > > > > "Xenor" wrote: > > Quote: > > > All, > > > I have a home built Vista Ultimate machine which I am attempting to setup > > > in a "remote" location in my house with wireless. The plan is to utilize a > > > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to PCI card > > > installed in my machine. I have already tested the WPC4400N in my laptop and > > > it works fine. The Rosewill PCMCIA to PCI card also appears to install > > > without any issues. (I do not have any other PCMCIA cards available to > > > test...) However, when windows detects the device and installs drivers > > > (either using Windows update or a manually) it does not work. There is a > > > Code 10 error on the Properties page in the Device manager. Problem Report > > > details are as follow: > > > > > > Product > > > Wireless-N Business Notebook Adapter > > > > > > Problem > > > Could not load driver software > > > > > > Date > > > 1/22/2008 1:00 PM > > > > > > Status > > > Report Sent > > > > > > Description > > > Windows was able to successfully install device driver software, but the > > > driver software encountered a problem when it tried to run. The problem code > > > is 10. > > > > > > Problem signature > > > Problem Event Name: PnPDeviceProblemCode > > > Architecture: x86 > > > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 > > > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} > > > PnP problem code: 0000000A > > > Driver name: NETMW145.sys > > > Driver version: 2.1.4.3 > > > Driver date: 01-08-2008 > > > OS Version: 6.0.6000.2.0.0.256.1 > > > Locale ID: 1033 > > > > > > Files that help describe the problem (some files may no longer be available) > > > DMIBB92.tmp.log.xml > > > LOGBBE1.tmp > > > oem12.inf > > > > > > Extra information about the problem > > > Bucket ID: 157734319 > > > > > > I'm fairly tech savvy, but once again generic/cross device error codes with > > > little detail have left me stuck. I have mucked around with PCI settings in > > > my BIOS to no avail. Any thoughts or suggestions? Thanks in advance for > > > your assistance. |
| Guest | Re: Problems with PCMCIA network card and the dreaded Code 10 erro Error code 10 means that the driver failed during startup. Usually the driver leaves a message in the System event log that is heplful to understand why. Have you checked the event log? --PA "Xenor" <Xenor@xxxxxx> wrote in message news:685623B4-DE19-4F74-BAD4-4ADDEF570CA3@xxxxxx Quote: > John, > I have faced this problem again in a new machine build. Ultimately, I > think that the folks doing the install of network drivers aren't cleaning > up > after themselves. I've found that by manually removing some of the > profiles > in the registry helps to clear the path for a clean install. It even > requires removing a service that is created by thy wireless networking > driver. I'm not sure who is to "blame" for it, but after searching > various > forums, it seems like many users of various Draft-N network adapters have > problems. The common thread seems to be the Marvell TOPDOG chipset which > various vendors use. Not sure if this is your area, but I'd like to pass > on > what I've learned to someone at Microsoft who could be working on a fix > for > this.. > > "JohnBuk [MSFT]" wrote: > Quote: >> Hello, >> >> I'm glad you were able to resolve your issue. Did the infcache.1 file >> get >> recreated after it was deleted? If not, if you you may want to consider >> reading the following article which addresses corruption and deletion of >> the >> infcache.1 file. The file will be needed for future installation of >> other >> devices. >> >> http://support.microsoft.com/?kbid=937187 >> >> John >> >> I work at Microsoft. These are my opinions and not my employers. >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> >> -- >> -- >> Speaking for myself only. >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> -- >> >> >> "Xenor" wrote: >> Quote: >> > Solved my own problem. Deleted the infcache.1 file in \Windows\Inf >> > >> > Maybe MS should auto check this file for corruption.....d >> > >> > "Xenor" wrote: >> > >> > > All, >> > > I have a home built Vista Ultimate machine which I am attempting >> > > to setup >> > > in a "remote" location in my house with wireless. The plan is to >> > > utilize a >> > > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to >> > > PCI card >> > > installed in my machine. I have already tested the WPC4400N in my >> > > laptop and >> > > it works fine. The Rosewill PCMCIA to PCI card also appears to >> > > install >> > > without any issues. (I do not have any other PCMCIA cards available >> > > to >> > > test...) However, when windows detects the device and installs >> > > drivers >> > > (either using Windows update or a manually) it does not work. There >> > > is a >> > > Code 10 error on the Properties page in the Device manager. Problem >> > > Report >> > > details are as follow: >> > > >> > > Product >> > > Wireless-N Business Notebook Adapter >> > > >> > > Problem >> > > Could not load driver software >> > > >> > > Date >> > > 1/22/2008 1:00 PM >> > > >> > > Status >> > > Report Sent >> > > >> > > Description >> > > Windows was able to successfully install device driver software, but >> > > the >> > > driver software encountered a problem when it tried to run. The >> > > problem code >> > > is 10. >> > > >> > > Problem signature >> > > Problem Event Name: PnPDeviceProblemCode >> > > Architecture: x86 >> > > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 >> > > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} >> > > PnP problem code: 0000000A >> > > Driver name: NETMW145.sys >> > > Driver version: 2.1.4.3 >> > > Driver date: 01-08-2008 >> > > OS Version: 6.0.6000.2.0.0.256.1 >> > > Locale ID: 1033 >> > > >> > > Files that help describe the problem (some files may no longer be >> > > available) >> > > DMIBB92.tmp.log.xml >> > > LOGBBE1.tmp >> > > oem12.inf >> > > >> > > Extra information about the problem >> > > Bucket ID: 157734319 >> > > >> > > I'm fairly tech savvy, but once again generic/cross device error >> > > codes with >> > > little detail have left me stuck. I have mucked around with PCI >> > > settings in >> > > my BIOS to no avail. Any thoughts or suggestions? Thanks in >> > > advance for >> > > your assistance. |
| | #6 (permalink) |
| Guest | Re: Problems with PCMCIA network card and the dreaded Code 10 erro I'm not sure. I just a scan for it, but couldn't find it. Does it matter that I get the error code when trying to install a driver. Do I need to turn on more verbose logging. My understanding was that driver installs acutally were written to the files "setupapi.app" and "setupapi.dev". I'll see if I can track down the full error code if you're interested... "Pavel A." wrote: Quote: > Error code 10 means that the driver failed during startup. > Usually the driver leaves a message in the System event log that > is heplful to understand why. Have you checked the event log? > > --PA > > > "Xenor" <Xenor@xxxxxx> wrote in message > news:685623B4-DE19-4F74-BAD4-4ADDEF570CA3@xxxxxx Quote: > > John, > > I have faced this problem again in a new machine build. Ultimately, I > > think that the folks doing the install of network drivers aren't cleaning > > up > > after themselves. I've found that by manually removing some of the > > profiles > > in the registry helps to clear the path for a clean install. It even > > requires removing a service that is created by thy wireless networking > > driver. I'm not sure who is to "blame" for it, but after searching > > various > > forums, it seems like many users of various Draft-N network adapters have > > problems. The common thread seems to be the Marvell TOPDOG chipset which > > various vendors use. Not sure if this is your area, but I'd like to pass > > on > > what I've learned to someone at Microsoft who could be working on a fix > > for > > this.. > > > > "JohnBuk [MSFT]" wrote: > > Quote: > >> Hello, > >> > >> I'm glad you were able to resolve your issue. Did the infcache.1 file > >> get > >> recreated after it was deleted? If not, if you you may want to consider > >> reading the following article which addresses corruption and deletion of > >> the > >> infcache.1 file. The file will be needed for future installation of > >> other > >> devices. > >> > >> http://support.microsoft.com/?kbid=937187 > >> > >> John > >> > >> I work at Microsoft. These are my opinions and not my employers. > >> This posting is provided "AS IS" with no warranties, and confers no > >> rights. > >> > >> -- > >> -- > >> Speaking for myself only. > >> This posting is provided "AS IS" with no warranties, and confers no > >> rights. > >> -- > >> > >> > >> "Xenor" wrote: > >> > >> > Solved my own problem. Deleted the infcache.1 file in \Windows\Inf > >> > > >> > Maybe MS should auto check this file for corruption.....d > >> > > >> > "Xenor" wrote: > >> > > >> > > All, > >> > > I have a home built Vista Ultimate machine which I am attempting > >> > > to setup > >> > > in a "remote" location in my house with wireless. The plan is to > >> > > utilize a > >> > > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA to > >> > > PCI card > >> > > installed in my machine. I have already tested the WPC4400N in my > >> > > laptop and > >> > > it works fine. The Rosewill PCMCIA to PCI card also appears to > >> > > install > >> > > without any issues. (I do not have any other PCMCIA cards available > >> > > to > >> > > test...) However, when windows detects the device and installs > >> > > drivers > >> > > (either using Windows update or a manually) it does not work. There > >> > > is a > >> > > Code 10 error on the Properties page in the Device manager. Problem > >> > > Report > >> > > details are as follow: > >> > > > >> > > Product > >> > > Wireless-N Business Notebook Adapter > >> > > > >> > > Problem > >> > > Could not load driver software > >> > > > >> > > Date > >> > > 1/22/2008 1:00 PM > >> > > > >> > > Status > >> > > Report Sent > >> > > > >> > > Description > >> > > Windows was able to successfully install device driver software, but > >> > > the > >> > > driver software encountered a problem when it tried to run. The > >> > > problem code > >> > > is 10. > >> > > > >> > > Problem signature > >> > > Problem Event Name: PnPDeviceProblemCode > >> > > Architecture: x86 > >> > > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 > >> > > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} > >> > > PnP problem code: 0000000A > >> > > Driver name: NETMW145.sys > >> > > Driver version: 2.1.4.3 > >> > > Driver date: 01-08-2008 > >> > > OS Version: 6.0.6000.2.0.0.256.1 > >> > > Locale ID: 1033 > >> > > > >> > > Files that help describe the problem (some files may no longer be > >> > > available) > >> > > DMIBB92.tmp.log.xml > >> > > LOGBBE1.tmp > >> > > oem12.inf > >> > > > >> > > Extra information about the problem > >> > > Bucket ID: 157734319 > >> > > > >> > > I'm fairly tech savvy, but once again generic/cross device error > >> > > codes with > >> > > little detail have left me stuck. I have mucked around with PCI > >> > > settings in > >> > > my BIOS to no avail. Any thoughts or suggestions? Thanks in > >> > > advance for > >> > > your assistance. > |
| | #7 (permalink) |
| Guest | Re: Problems with PCMCIA network card and the dreaded Code 10 erro Yep. Vista has lots of various logs, so confusing. But in this case you need just the old good eventlog (run eventvwr) --PA "Xenor" <Xenor@xxxxxx> wrote in message news:94E198C2-CC30-4413-8E43-7D38023076F1@xxxxxx Quote: > I'm not sure. I just a scan for it, but couldn't find it. Does it matter > that I get the error code when trying to install a driver. Do I need to > turn > on more verbose logging. My understanding was that driver installs > acutally > were written to the files "setupapi.app" and "setupapi.dev". I'll see if > I > can track down the full error code if you're interested... > > "Pavel A." wrote: > Quote: >> Error code 10 means that the driver failed during startup. >> Usually the driver leaves a message in the System event log that >> is heplful to understand why. Have you checked the event log? >> >> --PA >> >> >> "Xenor" <Xenor@xxxxxx> wrote in message >> news:685623B4-DE19-4F74-BAD4-4ADDEF570CA3@xxxxxx Quote: >> > John, >> > I have faced this problem again in a new machine build. Ultimately, >> > I >> > think that the folks doing the install of network drivers aren't >> > cleaning >> > up >> > after themselves. I've found that by manually removing some of the >> > profiles >> > in the registry helps to clear the path for a clean install. It even >> > requires removing a service that is created by thy wireless networking >> > driver. I'm not sure who is to "blame" for it, but after searching >> > various >> > forums, it seems like many users of various Draft-N network adapters >> > have >> > problems. The common thread seems to be the Marvell TOPDOG chipset >> > which >> > various vendors use. Not sure if this is your area, but I'd like to >> > pass >> > on >> > what I've learned to someone at Microsoft who could be working on a fix >> > for >> > this.. >> > >> > "JohnBuk [MSFT]" wrote: >> > >> >> Hello, >> >> >> >> I'm glad you were able to resolve your issue. Did the infcache.1 file >> >> get >> >> recreated after it was deleted? If not, if you you may want to >> >> consider >> >> reading the following article which addresses corruption and deletion >> >> of >> >> the >> >> infcache.1 file. The file will be needed for future installation of >> >> other >> >> devices. >> >> >> >> http://support.microsoft.com/?kbid=937187 >> >> >> >> John >> >> >> >> I work at Microsoft. These are my opinions and not my employers. >> >> This posting is provided "AS IS" with no warranties, and confers no >> >> rights. >> >> >> >> -- >> >> -- >> >> Speaking for myself only. >> >> This posting is provided "AS IS" with no warranties, and confers no >> >> rights. >> >> -- >> >> >> >> >> >> "Xenor" wrote: >> >> >> >> > Solved my own problem. Deleted the infcache.1 file in \Windows\Inf >> >> > >> >> > Maybe MS should auto check this file for corruption.....d >> >> > >> >> > "Xenor" wrote: >> >> > >> >> > > All, >> >> > > I have a home built Vista Ultimate machine which I am >> >> > > attempting >> >> > > to setup >> >> > > in a "remote" location in my house with wireless. The plan is to >> >> > > utilize a >> >> > > Linksys Draft N PCMCIA card (Model WPC4400N) in a Rosewill PCMCIA >> >> > > to >> >> > > PCI card >> >> > > installed in my machine. I have already tested the WPC4400N in my >> >> > > laptop and >> >> > > it works fine. The Rosewill PCMCIA to PCI card also appears to >> >> > > install >> >> > > without any issues. (I do not have any other PCMCIA cards >> >> > > available >> >> > > to >> >> > > test...) However, when windows detects the device and installs >> >> > > drivers >> >> > > (either using Windows update or a manually) it does not work. >> >> > > There >> >> > > is a >> >> > > Code 10 error on the Properties page in the Device manager. >> >> > > Problem >> >> > > Report >> >> > > details are as follow: >> >> > > >> >> > > Product >> >> > > Wireless-N Business Notebook Adapter >> >> > > >> >> > > Problem >> >> > > Could not load driver software >> >> > > >> >> > > Date >> >> > > 1/22/2008 1:00 PM >> >> > > >> >> > > Status >> >> > > Report Sent >> >> > > >> >> > > Description >> >> > > Windows was able to successfully install device driver software, >> >> > > but >> >> > > the >> >> > > driver software encountered a problem when it tried to run. The >> >> > > problem code >> >> > > is 10. >> >> > > >> >> > > Problem signature >> >> > > Problem Event Name: PnPDeviceProblemCode >> >> > > Architecture: x86 >> >> > > Hardware Id: PCI\VEN_11AB&DEV_2A02&SUBSYS_00651737&REV_03 >> >> > > Setup class GUID: {4d36e972-e325-11ce-bfc1-08002be10318} >> >> > > PnP problem code: 0000000A >> >> > > Driver name: NETMW145.sys >> >> > > Driver version: 2.1.4.3 >> >> > > Driver date: 01-08-2008 >> >> > > OS Version: 6.0.6000.2.0.0.256.1 >> >> > > Locale ID: 1033 >> >> > > >> >> > > Files that help describe the problem (some files may no longer be >> >> > > available) >> >> > > DMIBB92.tmp.log.xml >> >> > > LOGBBE1.tmp >> >> > > oem12.inf >> >> > > >> >> > > Extra information about the problem >> >> > > Bucket ID: 157734319 >> >> > > >> >> > > I'm fairly tech savvy, but once again generic/cross device error >> >> > > codes with >> >> > > little detail have left me stuck. I have mucked around with PCI >> >> > > settings in >> >> > > my BIOS to no avail. Any thoughts or suggestions? Thanks in >> >> > > advance for >> >> > > your assistance. >> |
| SD card error code 38 | Vista hardware & devices | |||
| ZTE MF330 PCMCIA card | Vista hardware & devices | |||
| Problems with PCMCIA firewire card and crashes | Vista hardware & devices | |||
| Installing a PCMCIA Card Drive in desktop to use PC5740 card in | Vista networking & sharing | |||
| Flash OFDM Flarion PCMCIA device could not start - error code 10 | Vista hardware & devices | |||
