Vista Tutorial - Natural Ergonomic 4000 problem
Old 01-24-2008   #1 (permalink)
Junior Member
Vista Home Premium 64bit
Ive downloaded and used this driver microsoft recommended but am having trouble
IntelliType Pro 6.1 64-bit for Windows Vista
for example the f keys won't work for example i can't hit alt+f4 to close a window. any help with this problem is much apreciated.
Old 01-25-2008   #2 (permalink)
Dwarf
Guest
RE: Natural Ergonomic 4000 problem
Hi Maccaro,
As far as I am aware, this keyboard, in common with a lot of keyboards on
the market, gives the function keys 2 functions. One of these is the standard
F1-F12, but the other is denoted by what is written on the keys. For example,
mine has 'Help' on F1, 'New' on F4, 'Save' on F11 and 'Print' on F12 to name
just a few. On your keyboard there should be a key called 'F Lock'. This is a
toggle switch just like 'Num Lock', 'Caps Lock' and 'Scroll Lock'. Check the
LED indicators on your keyboard, there should be one for each of these
functions. With the 'F Lock' indicator OFF the function keys act according to
the function written on them and when the indicator is ON they act according
to the standard F1-F12.
Dwarf
"Maccaro" wrote:
> trouble
> 'IntelliType Pro 6.1 64-bit for Windows Vista'
> (http://download.microsoft.com/downlo...7/ITP64Eng.exe)
> Maccaro
Old 01-25-2008   #3 (permalink)
Junior Member
Re: Natural Ergonomic 4000 problem
Thanks alot for that its working now.
Microsoft Natural Keyboard 4000 Keys Repeating Vista hardware & devices
MS Natural Keyboard 4000/Vista: Hotkey to open/close optical drive Vista hardware & devices
MS Natural Keyboard 4000 F keys... Vista hardware & devices
Microsoft Hardware Advances Ergonomic Leadership With First Natural Ergonomic Mouse Vista News
