Vista - Wireless Optical Desktop 1000 Battery Slot
Old 01-25-2008   #1 (permalink)
DanMat6288
There seems to be an issue with the width of the battery slot on the keyboard
that comes with the Microsoft Wireless Optical Desktop 1000. The space that
the first battery gets put in is so tight, the battery needs jammed in, and
it's nearly impossible to remove it again. I had to take apart my keyboard
just to remove that battery. Is this an issue with all keyboards from this
set, or is mine just faulty?
Sincerely,
DanMat6288
Microsoft wireless optical desktop 1000 Vista General
Wireless 3000 optical mouse How do u install battery? .NET General
WINDOWS Wireless Optical Desktop 1000 and Vista 64bit!! Vista hardware & devices
Windows Wireless Optical Desktop 3.0a Vista General
Microsoft Wireless Desktop 1000 Vista hardware & devices
