Vista - problems printing in MS Works
Old 01-30-2008   #1 (permalink)
Betsanne
I have a Dell laptop running vista premium with MS Works. My printer is an
HP deskjet 4240. I can't use the menu commands, print preview, or even print
in the daatabase or spreadsheet. Everything is fine in Word. The printer
works fine with all other programs. If I set the default printer on the MS
XPS documet writer I can use all the menu commands but I still can't print.
The driver is current, I've tried uninstalling & re installing both Works &
the printer; system restore; spent 1 1/2 hours on the phone with Dell and
still I have not found a solution. Device manager shows everything is
working fine. HELP!!! I'm totally stumped!
printing labels microsoft works Vista print fax & scan
HP Officejet 5610 printing multiple pages with Works 7.0 with vist Vista General
Printing with Works on Vista Vista print fax & scan
Fix for printing Works doc created another problem (Vista) Vista General
Works 8.5 printing Vista General
