Vista - Problem caused by NVIDIA Graphics Driver
Old 02-04-2008   #1 (permalink)
Brian
Hello,
I have a HP DV9500 and my computer shuts down while on windows vista.
I get the following error:
This problem was caused by NVIDIA Graphics Driver. This program was created
by NVIDIA Corporation. NVIDIA Corporation does not currently have a solution
for the problem that you reported.
Recommendation
The following troubleshooting steps might prevent the problem from recurring.
Download and install an updated version of NVIDIA Graphics Driver from one
of the following locations:
Microsoft Update
NVIDIA Corporation
If an updated driver is not available for NVIDIA Graphics Driver, check with
your computer manufacturer.
If you are running the latest version of NVIDIA Graphics Driver, contact
NVIDIA Corporation for your support options.
Additional information
If this problem continues to occur after installing the latest product
updates, we recommend you get assistance and troubleshooting information
directly from NVIDIA Corporation.
*** I went to nvidia to get an updated driver - there fix is to contact HP.
I
contacted HP and they sent me thier latest driver. I deleted my old driver
and installed thiers. When i installed thier latest driver, i got the "yes
to all" meaning, I had it already. My computer still shuts down... I've
talked to HP twice and looked all over windows to find a fix...still no fix.
Can anyone out there help me and Maddi below? Please... Thanks in advance
Problem caused by NVIDIA nForce(TM) SATA Driver Vista General
Vista NVIDIA Graphics Driver problem Vista installation & setup
Help! nVidia 7950GX2 graphics card driver problem Vista performance & maintenance
Nvidia graphics driver bug Vista General
Nvidia graphics driver bug Vista hardware & devices
