| | help default window uses what login |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: help Hi Char, Not sure what you mean. By default Vista uses what you what you setup during installation for the Username and Password. If you bought a computer with Vista preinstalled, then the password is usually blank and simply clicking on the user icon or pressing Enter on Password will let you logon. If this is not what you meant, then please let us know with more details on what you meant. Shawn |
| | Re: help If you mean, "If I don't log in or select a user when Windows starts, what login does Windows use?" the answer is, "The first, and only, login created when Windows was set up." If there is more than one login present, Windows will default to showing the welcome screen where you can pick an account to log into. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "char" <char@xxxxxx> wrote in message news:FFC5BFC0-696A-45CD-A2FB-6D2A74B4B360@xxxxxx Quote: > default window uses what login > |
