Vista - Re: Sound from headphones, but not without headphones?
Old 02-06-2008   #1 (permalink)
mforbes
I didn't have any sound issues before, but the other day I used
headphones on my laptop, and now, I can't hear anything WITHOUT
headphones.
So, when I plug in headphones, I can hear sounds. If I unplug the
headphones, no sound comes out of the speakers on my laptop.
I've checked the volume, checked to make sure it's not muted...I'm
stumped. Any suggestions?
Thanks!!
Michelle
mforbes
mforbes's Profile: http://forums.techarena.in/member.php?userid=41177
View this thread: http://forums.techarena.in/showthread.php?t=909361
Old 02-07-2008   #2 (permalink)
JerryM
I get the same results if my headphones are plugged in also, but if I unplug
the headphones and restart the program, my speakers work just fine.
Try rebooting with the headphones unplugged.
Jerry
"mforbes" <mforbes.34dd7f@xxxxxx> wrote in message
news:mforbes.34dd7f@xxxxxx
> headphones.
> Thanks!!
> Michelle
> mforbes
Old 03-17-2008   #3 (permalink)
sharski
I have the same problem, but the problem doesn't go away after a reboot. I
went online with DELL for 2 hrs. We checked all settings, reinstalled sound
driver, reset BIOS, restarted computer from a safe state two days before the
problem occured. Still no sound from PC, it only works with headphones.
DELL said next step is to install OS! Any ideas out there?
Thanks!
> Jerry
> > headphones.
> > Thanks!!
> > Michelle
> > mforbes
No sound via headphones Sound & Audio
No Sound in Headphones Vista performance & maintenance
no sound from my headphones Vista General
No sound with headphones Vista hardware & devices
No Sound from Headphones Vista hardware & devices
