Vista - No "Bluetooth Devices" in Control Panel
Old 08-04-2006   #1 (permalink)
=?Utf-8?B?SXdvbmE=?=
I plugged in my bluetooth USB adapter and the driver installed without a
problem and now appears under Bluetooth Devices in Device Manager as
"Kensington Bluetooth EDR Dongle", which is the correct driver.
However, I do not have Bluetooth Devices in Hardware and Sound under Control
Panel. Moreover, I do not have the file windows\system32\bthprops.cpl, which
I read about in related posts.
I have build 5472 upgraded from clean Beta 2, but also with clean Beta 2 I
had the same problem.
Old 09-07-2006   #2 (permalink)
=?Utf-8?B?U2Ft?=
RE: No "Bluetooth Devices" in Control Panel
I am experiencing the same problem, even in RC1. I have a IoGear GBU311
Bluetooth receiver; I plug it in (though the drivers didn't install
automatically - I pointed it to the XP driver set and it installed with no
aparrent issues). However I do not have the Bluetooth Control Panel. It is
recognized as a Broadcom Bluetooth device in device manager.
"Iwona" wrote:
> Hi,
Old 10-21-2006   #3 (permalink)
frustrated1980
I also have this problem. Has anyone figured out the answer yet?!
"Iwona" wrote:
> Hi,
Removing Bluetooth Devices Icon from Control Panel - Windows Vista Business Vista performance & maintenance
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Vista General
Control Panel open causes "Windows Explorer has stopped working".... Vista General
Missing Bluetooth Devices in Control Panel Vista hardware & devices
No Bluetooth Devices in Control Panel Vista hardware & devices
