my DVD drive
  1. #1
    Fidel Guest
    my DVD drive
    this just started. I have an acer laptop runing vista I also have norton
    running as my viruis protection. When I try to play a dvd I get the following
    message when I try to access the drive. "windows cannot access the specified
    devise, path or file. you may not have the appropriete permission to access
    them" also before this my dvd's would auto run a play with not problems. By
    the way I'm the administrator even though there are no other users for my
    laptop
  2. #2
    John F Guest
    RE: my DVD drive
    See if Windows update installed 943899 on your system, if it did remove it.
    See KB 943899 for the explanation.
    John F
    > laptop
my DVD drive problems?
Windows 2003: Replacing Drive with Boot.ini file. Can I move it toother drive? mitchkill Server General 6 15 Sep 2009
Combo RAID1 and standard Drive setup problem - Unallocated Drive ERdoc General Discussion 0 25 Jun 2009
Access XP data drive using Vista Ult (XP drive=slave drive only NO John C (Go Packers!) Vista account administration 0 23 Jun 2008
Vista on the C: drive but System drive is the D: drive - any way to hinnc Vista installation & setup 4 15 Nov 2007
Vista maping drive to server 2000 shared drive not recognize user/ Sam Vista networking & sharing 1 02 Nov 2007
