| | USB WON'T READ THUMB DRIVE I've got windows VISTA. All was well till 1 Feb 08. Put my camera card in the xd slot and it said "Microsoft Windows You need to format the disk in drive F: before you can use it. Do you want to format it? (Format disk) (Cancel)". I tried to format it and it wouldn't do it. Then I discovered it was saying the same thing when I put in a thumb drive! I've checked everything and it says the device is working properly but IT ISN'T. Mouse receiver (USB) is working. HotSync (USB) to my phone is working. |
| Vita Home Premium 32 bit | Re: USB WON'T READ THUMB DRIVE I am having the same problem....no USB memory will work and neither will my memory sticks.....always told that the disk needs to be formatted, although they all work in XP computer and digital camera. Did you ever get this resolved? I've got windows VISTA. All was well till 1 Feb 08. Put my camera card in the xd slot and it said "Microsoft Windows You need to format the disk in drive F: before you can use it. Do you want to format it? (Format disk) (Cancel)". I tried to format it and it wouldn't do it. Then I discovered it was saying the same thing when I put in a thumb drive! I've checked everything and it says the device is working properly but IT ISN'T. Mouse receiver (USB) is working. HotSync (USB) to my phone is working. |
| USB thumb drive read only | Vista security | |||
| USB Thumb drive, Protection | Vista General | |||
| bootable thumb drive | General Discussion | |||
| U3 thumb drive doesn't work | Vista hardware & devices | |||
| Mapped drive letters get re used when plugging in USB Thumb Drive | Vista networking & sharing | |||
