Vista - Difference between Physical Memory and the Vista System Memory (Ra
Old 02-20-2008   #1 (permalink)
DP
4GB DDR SDRAM DIMM ( Two @ Corsair XMS Twin2048-3200c2) on MSI 865PE/GNeo2
Motherboard with a Pentium 4 3.0GHz CPU
SiSoft Sandra is indicating Physical memory of four 1GB Dimm SDRAM double-bank
Vista System page is indicating Memory (Ram) of 3070 MB
Why and what is the significance if any?
Old 02-20-2008   #2 (permalink)
Colin Barnhorst
Re: Difference between Physical Memory and the Vista System Memory (Ra
The system properities page is reporting the memory available to user
programs. The BIOS is reserving the remaining for such things as
memory-mapped IO for things like your video card. This is normal. Don't
worry about it.
"DP" <DP@xxxxxx> wrote in message
news:45C805FB-9A4C-4D58-980A-C85477229937@xxxxxx
> 865PE/GNeo2
> double-bank
Old 02-20-2008   #3 (permalink)
JW
Here is a good KB article on the issue. Your system is reserving the 1 GB
of memory addresses to be used by hardware cards/interfaces such as your
graphics card which have their on onboard memory and regretfully the 1GB is
not available to your system.
http://support.microsoft.com/kb/929605/en-us
> 865PE/GNeo2
> double-bank
4GB of physical memory shows as less than 3 in system properties Vista General
installed physical memory vs total physical memory General Discussion
Vista 64 Installed Physical Memory vs Total Physical Memory Vista General
Installed Physical Memory/Total Physical Memory Vista installation & setup
Ati Radeon 9550 using system memory? 511mb shared system memory. Vista hardware & devices
