Vista - CPU Speed
Old 02-20-2008   #1 (permalink)
Daniel
CPU Speed
Hi
I have Vista Ultimate.
My CPU is a Pent D Extreme Edition 3.2 Ghz, when I run CPU-Z it shows Core
Speed
at 2800.4 or lower, dropping below 2798.1 at times.
Why is that, how do I get it to run at 3200 all the time?
thanks
Daniel
Old 02-20-2008   #2 (permalink)
peter
Re: CPU Speed
what are your BIOS settings for FSB and Muliplier??
peter
DISCLAIMER: If you find a posting or message from me
offensive, inappropriate, or disruptive, please ignore it.
If you don't know how to ignore a posting, complain to
me and I will be only too happy to demonstrate... ;-)
"Daniel" <noone@xxxxxx> wrote in message
news:ex5IDP$cIHA.1132@xxxxxx
Quote:
> Hi
> Speed
> thanks
> Daniel
Old 02-20-2008   #3 (permalink)
Tom Lake
Re: CPU Speed
Quote:
> Hi
> Speed
It's built to throttle down when full speed is not needed.
This keeps it cooler and saves energy. It will run at full speed
when there are tasks to be done. Why would you
want it to run at full speed just running an idle loop?
Tom Lake
Old 02-20-2008   #4 (permalink)
Daniel
Re: CPU Speed
BIOS FSB is 800,
I cannot find Multiplier in BIOS but
CPU-Z reports it as 16.
cheers
Daniel
"peter" <peter@xxxxxx> wrote in message
news:uwUpJ$$cIHA.1168@xxxxxx
> peter
Quote:
>> Hi
>> Core Speed
>> thanks
>> Daniel
Old 02-20-2008   #5 (permalink)
Gary Mount
Re: CPU Speed
From Intel...
"Enhanced Intel SpeedStep technology allows the system to dynamically adjust
processor voltage and core frequency, which can result in decreased average
power consumption and decreased average heat production. By decreasing power
and heat on Desktop PCs, system builders can (depending on system
configurations) potentially lower acoustics, and even develop more
innovative small form factor designs. Additionally, this feature can help
address power concerns in companies with sites approaching the limits of
bounded electrical infrastructures. Combined with existing power saving
features, Enhanced Intel SpeedStep technology can provide an excellent
balance between providing power when you need it and conserving it when you
don't
Quote:
> Hi
> Speed
> thanks
> Daniel
Old 02-20-2008   #6 (permalink)
mikeyhsd
Re: CPU Speed
try adjusting your power mode setting and see if it helps.
you are probably using balanced. it allows the cpu to throttle down.
mikeyhsd@xxxxxx
"Daniel" <noone@xxxxxx> wrote in message news:ex5IDP$cIHA.1132@xxxxxx
Hi
Speed
thanks
Daniel
Old 02-22-2008   #7 (permalink)
Daniel
Re: CPU Speed
""try adjusting your power mode setting and see if it helps.
you are probably using balanced. it allows the cpu to throttle down.""
I am using "High Performance" power options with nothing turning off
"Enhanced Intel SpeedStep " is not available, the option does not appear
on my Motherboard..
""Why would you
I would have thought the CPU would run at full speed when being tested
cheers
Daniel
"mikeyhsd" <mikeyhsd@xxxxxx> wrote in message news:O249gpBdIHA.748@xxxxxx
mikeyhsd@xxxxxx
Hi
Speed
thanks
Daniel
Old 02-26-2008   #8 (permalink)
Paul Smith
Re: CPU Speed
Perfectly normal, the CPU will throttle down when there's nothing to do.
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.dasmirnov.net/blog/
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
Quote:
> Hi
> Speed
> thanks
> Daniel
Can you speed up download speed from ISP General Discussion
Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. Vista General
Help! Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. Vista networking & sharing
Network speed is half or one third of speed on XP Vista General
How to check your Speed Boost tested memory speed Vista General
