| | Help - TSSTcorp DVD+-RW TS-L632H ATA TSSTcorp DVD+-RW TS-L632H ATA. Hi, I’m Carlos, asking for help, I’m runnig Windows Vista Home Basic (32 bits) and my laptop is a Dell Vostro 1000. Somehow I have lost the driver information for the Cd drive, it is a TSSTcorp DVD+-RW TS-L632H ATA device, when you go to the device manager there is a little yellow exclamation mark, further still in volumes (I think) there is no data. There is an error 39 which I have not worked out what it is yet. I have tried inserting the driver disk supplied but obviously it wont work. I have also tried as suggested allowing the computer to look for drivers on the internet. It tells me that it is up to date.?. I’ve tried this: uninstall the current driver, then click scan for hardware changes or reboot and reinstall the driver. Doesn’t work eather, it says it couldn’t installed it contact TSST I’ve heard a solution only for windows XP, removing lower and upper filters with the same problem that appears to happen uninstalling Roxio Easy Creator, which I have but I have no uninstalled http://support.dell.com/support/topi...=us&l=en&s=dhs Hopefully this makes sense. thank you in advanced |
| | Re: Help - TSSTcorp DVD+-RW TS-L632H ATA It worked!! Thank u so mach. I was fed up looking for a solution. Thaaaaaank u Cal Bear '66' "Cal Bear '66" wrote: Quote: > Deleting the upper and/or lower filters in the registry also works for Error 39 > in Vista. > > See: > > http://support.microsoft.com/default.aspx/kb/929461 > > > I Bleed Blue and Gold > GO BEARS! > > > "Carlos" <Carlos@xxxxxx> wrote in message > news:0AA89B40-2EDC-425F-B37A-550DF43A4D1D@xxxxxx Quote: > > TSSTcorp DVD+-RW TS-L632H ATA. > > Hi, I'm Carlos, asking for help, I'm runnig Windows Vista Home Basic (32 > > bits) and my laptop is a Dell Vostro 1000. Somehow I have lost the driver > > information for the Cd drive, it is a TSSTcorp DVD+-RW TS-L632H ATA device, > > when you go to the device manager there is a little yellow exclamation mark, > > further still in volumes (I think) there is no data. There is an error 39 > > which I have not worked out what it is yet. I have tried inserting the driver > > disk supplied but obviously it wont work. > > I have also tried as suggested allowing the computer to look for drivers on > > the internet. It tells me that it is up to date.?. > > I've tried this: uninstall the current driver, then click scan for hardware > > changes or reboot and reinstall the driver. Doesn't work eather, it says it > > couldn't installed it contact TSST > > I've heard a solution only for windows XP, removing lower and upper filters > > with the same problem that appears to happen uninstalling Roxio Easy Creator, > > which I have but I have no uninstalled > > http://support.dell.com/support/topi...=us&l=en&s=dhs > > > > Hopefully this makes sense. thank you in advanced > > > |
| | Re: Help - TSSTcorp DVD+-RW TS-L632H ATA I Cannot Use This Drive When I Open Roxio Creator De It Said "in Use By Visitor" On The Disk Icon Lower Left Conrner Or My Emc 9. The Top Window Shows Drive In Use By Visitor. Please Wait Until That Project Is Completed And Try Again. I Have Tried Many Ways To Solve But It Doesnt Work. Any Idea ???? -- INSPIRON1526 ------------------------------------------------------------------------ INSPIRON1526's Profile: http://forums.techarena.in/member.php?userid=50780 View this thread: http://forums.techarena.in/showthread.php?t=919663 http://forums.techarena.in |
| | Re: Help - TSSTcorp DVD+-RW TS-L632H ATA It would help if you tell us what 'many ways' you have tried. For example, have you tried uninstalling and reinstalling the drive? Do you have other DVD burning software installed? Have you tried uninstalling and reinstalling Roxio? Does it work with Vista's built in DVD Maker? -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows "INSPIRON1526" <INSPIRON1526.3aahfd@xxxxxx> wrote in message news:INSPIRON1526.3aahfd@xxxxxx Quote: > > I Cannot Use This Drive When I Open Roxio Creator De > > It Said "in Use By Visitor" On The Disk Icon Lower Left Conrner Or My > Emc 9. > > The Top Window Shows Drive In Use By Visitor. Please Wait Until That > Project Is Completed And Try Again. > > I Have Tried Many Ways To Solve But It Doesnt Work. > > Any Idea ???? > > > -- > INSPIRON1526 > ------------------------------------------------------------------------ > INSPIRON1526's Profile: http://forums.techarena.in/member.php?userid=50780 > View this thread: http://forums.techarena.in/showthread.php?t=919663 > > http://forums.techarena.in > |
| TSSTCorp CDDVDW TS-L632H ATA Driver problem error code 19 | Drivers | |||
| TSST corp CDDVDW TS-L632H ATA device | Drivers | |||
| TSSTcorp Driver | Drivers | |||
| cd dvd TSSTcorp DVD+-RW TS-L632H ATA Device not working | Drivers | |||
| TSSTcorp CD/DVDW TS-653L | Drivers | |||
