| | Sound problems with Realtek Audio Hi there, Using Vista Ultimate x32 edition. Just installed Vista and installed all the latest drivers for my devices. Im using Realtek HD audio Manager which is the correct driver for my onboard sound card. The problem though is that sound is only coming out from the front right speaker. Nothing is coming out of the rest of the speakers when I play music. However when I go to test the speakers using the Realtek manager , I can hear sound coming out of all of the 5.1 speaker system. This is strange, there is sound coming out of all the speakers when I test them but when I try to play music it only comes out of the front right speaker. I tried turning up the volume on every single dial on the Windows Sound Manager and on the Realtek Sound manager. I checked all the drivers and even rolled them back but still to no avail. Everything has been configured correctly, because I had Vista 32 bit yesterday but I decided to do a format and clean install again. It was working fine yesterday but not today. |
| Win7 64bit Ultimate | Re: Sound problems with Realtek Audio if it was working yesterday try a system restore |
| | Re: Sound problems with Realtek Audio I cant do a system restore because I formatted my Hard Drive and installed a fresh copy of Vista 32bit! "caretaker" wrote: Quote: > > if it was working yesterday try a system restore > > > -- > caretaker > |
| Win7 64bit Ultimate | Re: Sound problems with Realtek Audio Try to remove the Driver and reinstall it as you may have gotten the prerequisite updates from ms you you would have gotten them after it installed the sound card drivers. those updates can corrupt your sound drivers, so please try a reinstall of the drivers as now the will be different and let MS install them via update. |
| Vista Home Premium 32bit | Re: Sound problems with Realtek Audio I have had similar issues over the past few days, since downloading the latest Vista updates. I tried uninstalling, reinstalling, deleting etc with no luck. However, I had a back up drive & noticed that the drivers there were visible. While on my current drive they were not. Even though during the driver loading process, it showed that the driver were being placed in Program Files. Subsequently, I downloaded the drivers in the zipped form, created a folder under Programs called Realtek and physically dumped the files in there. After rebooting, Vista found the drivers and all is working as well as can be expected. regards |
| 32 bit vista no sound realtek hd audio manager missing | Sound & Audio | |||
| Bad sound from Realtek HD Audio | Sound & Audio | |||
| No analog sound from Realtek HD Audio | Vista hardware & devices | |||
| No analog sound with Realtek HD Audio | Vista General | |||
| 5.1 sound problems on Realtek ALC655 on board sound. | Vista hardware & devices | |||
